Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Old 01-18-2007, 02:24 AM   #1
Hqct .net Addin!
Hello everybody! I'm working on a .net addin using the .net HQCT project. I have no idea if this will even work (as I do not have streetdeck installed on my desktop nor do i have an hqct on my desktop) but I made a simple little addin. I would appreciate it if someone could try this out and let me know if it even works or whatever... thanks.
UPDATE: I went ahead and bought streetdeck, took the HQCT out of my car and hooked it up to my desktop, worked on the plugin, and it WORKS! You can try it out yourself by downloading it here: http://www.pogi.org/HQCT%20Addin.sdz
If it gets renamed to .zip just rename it back to .sdz. Also, after you install it, you have to manually register the .dll's by using RegAsm.exe with the /codebase parameter. If someone can post sample ComRegisterFunction code to register extra DLL's that would be great. THanks to everybody that worked on the C# implementation of the HQCT stuff.
pogitalonx is offline   Reply With Quote
Old 01-18-2007, 06:17 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
You know that you can download the trial for 30 days...
It's the same as the developer edition.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-19-2007, 08:22 AM   #3
strohj's Avatar
oh man I am gonna have to go buy a HQCT radio now....
what are the chances that streetdeck will incorporate digitalmods straight into the app if it becomes a popular digitalmod?
strohj is offline   Reply With Quote
Old 01-19-2007, 08:33 AM   #4
_
kudos!
If I had a HQCT, I'd jump on it. Might have to take the plunge on it.
As for a digimod being integrated, I'm not sure what the method for determining this is.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 01-19-2007, 01:15 PM   #5
you can change your skin to make the digital mod right on the front screen, just as if it was integrated. I'm using GPL'd stuff (the C# HQCT project) so I dont think this will ever be fully "integrated"... but it is really easy to change your skin to make the "radio" button load the digitalmod instead of the normal radio.
Old 01-19-2007, 01:18 PM   #6
strohj's Avatar
sounds like I finally need to watch that skinning video
Old 01-19-2007, 01:19 PM   #7
Oh yea, one more thing... I think this will also work with the HQCTe.... which might be what the streetdeck folks have been waiting for. Supposedly its coming out in the next week or so (at least the first 10 units)! Exciting times..
Old 01-21-2007, 05:27 PM   #8
Update (read first post)
Old 07-28-2007, 03:04 PM   #9
jAyRoCkS24r's Avatar
Does your hcqt plugin support any rds rdbs support? I tried installing sdz package but got an error. I was traveling for work this week and had a car with rdbs and it makes FM much more enjoyable and friendly to a carPC? Any information with be great!
Engineering....Where the unknowing teach the unwilling the unnecessary.
jAyRoCkS24r is offline   Reply With Quote
Old 07-29-2007, 10:24 AM   #10
Addin problem
Hi. great job with the plugin.
I'm having a bit of trouble though...
after installing and manually regging the dll's my SD wont start
resulting in an error stating that button.misc.nofocus.png is missing
which of course it is....nowhere to be found. deleting the folder in scripts
makes SD start again.
any ideas?
/Markus
bseosoo is offline   Reply With Quote
Old 08-06-2007, 08:38 PM   #11
pim
Hmm, me too.
Pogitalonx, won't you release source code, so we might see what's happening, maybe even fix it?
Pim
pim is offline   Reply With Quote
Old 10-21-2007, 08:20 AM   #12
ok, after a tough summer of working i finally pulled myself together and decided to move on with the project;
simply creating the missing png-file in the skin dir, solved it, DOH!
what was I thinking?
just have to figure out the look of the png for it not to look nasty...
cya'll
Old 12-15-2007, 07:11 PM   #13
after a while of trying to get in touch with pogi about a tuning issue, i stumbled across this: http://www.mp3car.com/vbulletin/digi...ager-beta.html
i'll be looking into this as an alternative as soon as i get some time to do it
the addin is still in beta but there seem to be some recent activity about it.
sendMessage from a .Net App ruairi Road Runner 15 09-30-2007 12:32 PM
VoomPC Ampie Case and HQCT module mcfennek General Hardware Discussion 2 07-16-2006 04:16 PM
HQCT Library mtrax Newbie 0 05-31-2006 02:21 AM
Error installing .Net framework 1.1.4322 proximo WinNT Based 4 05-19-2006 04:07 AM
Using Destinator SDK with .NET BrainCore Map Monkey 2 05-08-2006 04:53 AM
