03-11-2008, 11:04 PM
#1
Fusion Brain Creator
Tutorial - Air Ride Suspension
Hardware
So far, the only sensors we have data for are the Dakota Digital sensors.
http://www.dakotadigital.com/index.c...rod/prd124.htm
Code:
150psi, 1/8-27 NPT
PSI R typical R max R min
0 10 13 5
14.5 31 35 27
29 52 56 48
43.5 70 74 66
58 88 92 84
72.5 106 111 101
87 124 129 119
101.5 140 150 130
116 155 170 145
130.5 170 185 155
145 184 214 154
Maximum 435 psi for 2 seconds only.
Operating Temperature: -13F - +212F (to +248F max. 1 hour) on
connecting thread.
Then, all you need to do is hook the air ride sensor up like so, knowing that the body of the sensor is grounded.
As far as software, Nick will be along shortly to do that bit.
03-11-2008, 11:21 PM
#2
Vehicle: 2001 Honda Civic EX Coupe
To Evaluate an Analogue Input as an Air Ride Sensor
Code:
<?xml version="1.0" encoding="utf-8" ?>
<function>
<input order="1">PressureInput</input>
<return type="numeric">
<operation type="subtract">
<parameter1>
<number>18.313</number>
</parameter1>
<parameter2>
<operation type="add">
<parameter1>
<parameter1>
<operation type="multiply">
<parameter1>
<number>8.4879</number>
</parameter1>
<parameter2>
<parameter1>
<parameter1>
<variable do="get">PressureInput</variable>
</parameter1>
<parameter2>
</parameter2>
</operation>
</parameter1>
<parameter2>
</parameter2>
</operation>
</parameter2>
</operation>
</parameter1>
<parameter2>
<parameter1>
<number>27.568</number>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
</parameter2>
</operation>
</parameter2>
</operation>
</parameter2>
</operation>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>49.943</number>
</parameter2>
</operation>
</parameter2>
</operation>
</parameter2>
</operation>
</return>
</function>
03-11-2008, 11:26 PM
#3
To Use above code
Insert this into your logic area (between "<logic>...</logic>". You obviously need to replace the analogue id with the id you declare in the io section "<io>...</io>". And you must reference the above code in a seperate function file in the "<require></require>" area.
**Note: The "..." in the following code mean that there can/will be other non-related items between the code sections. Fusion Control Centre Uber Edition doesn't care about the order. It only cares about heirarchy. Meaning "<iochannel>...</iochannel>" must occur between the opening "<io>" and closing "</io>" tags. If it is not in there, FCC will skip right over it, and that input channel will never be created.
Code:
<require>
<!-- Begin Function Instances -->
<function file="content\config\AirRidePressureSensorModule" id="AirPressureSensor"></function>
<!-- End Function Instances -->
</require>
<io>
<!-- Begin Analogue Input Instances -->
<iochannel id="RF Air" port="0" brain="TucciBrain2" type="analogue_input">
<options history="10" auto_average="true"></options>
</iochannel>
<iochannel id="LR Air" port="1" brain="TucciBrain2" type="analogue_input">
</iochannel>
<iochannel id="LF Air" port="2" brain="TucciBrain2" type="analogue_input">
</iochannel>
<iochannel id="RR Air" port="3" brain="TucciBrain2" type="analogue_input">
</iochannel>
<!-- End Analogue Input Instances -->
</io>
<logic>
<!-- Begin Variable Declarations -->
<all_variables>
<variable name="Variable_LeftFrontAir">50.0</variable>
<variable name="Variable_LeftRearAir">50.0</variable>
<variable name="Variable_RightFrontAir">50.0</variable>
<variable name="Variable_RightRearAir">50.0</variable>
</all_variables>
<!-- End Variable Declarations -->
<all_statements>
<if fire_on="logic">
<parameter1>
<variable do="set" name="Variable_LeftFrontAir">
<evaluate function="AirPressureSensor">
<input order="1">
<analogue id="LF Air" time="0"></analogue>
</input>
</evaluate>
</variable>
</parameter1>
</if>
<parameter1>
<variable do="set" name="Variable_LeftRearAir">
<input order="1">
<analogue id="LR Air" time="0"></analogue>
</input>
</evaluate>
</variable>
</parameter1>
</if>
<parameter1>
<variable do="set" name="Variable_RightFrontAir">
<input order="1">
<analogue id="RF Air" time="0"></analogue>
</input>
</evaluate>
</variable>
</parameter1>
</if>
<parameter1>
<variable do="set" name="Variable_RightRearAir">
<input order="1">
<analogue id="RR Air" time="0"></analogue>
</input>
</evaluate>
</variable>
</parameter1>
</if>
</allstatements>
</logic>
03-12-2008, 08:19 AM
#4
Vehicle: 2008/Scion/Xb
2k1toaster,
In what program does this have to be written in?
and
I see that this is an XML, Will I need to open this in a webpage? can I incorporate it to Streetdeck some how?
Where is the <io></IO> section?
03-12-2008, 12:09 PM
#5
Quote: Originally Posted by dasaint80
2k1toaster,
and
You can write this is any program that supports either xml (Dreamweaver, Word, Free XML Editors scattered around google), or in any plain text editor (Notepad and free ones too, just save the file as *.xml not *.txt).
You do not need or have to open it in a web browser. You can if you want to view the xml if you have no editor (which if you run windows you do, Start-->Programs-->Accessories-->NotePad).
This code is only understandable by Fusion Control Centre Uber Edition (FCC). Currently, the latest release of Uber is MDX (Managed DirectX) and downloadable as shown here: http://www.mp3car.com/vbulletin/docu...rsion-mdx.html
To incorporate into StreetDeck, currently you must embed FCC into Streetdeck as an external program. I have been working on a COM object (I promise I have been, but it is slow going now because of how Vista changed COM objects) which will allow the Fusion Brain to be controlled via a plugin (DigitalMod I believe is the SD term). This COM functionality is not available yet, but I hope it will be before summer. Until then, embedding the program works well. You may have to run SD in "testmode" to enable usage while moving.
03-31-2008, 06:40 PM
#6
Code:
<require>
<!-- Begin Font Instances -->
<font name="LED50" originalSize="50" font_config="Content\config\fonts\FusionFontLED.xml"></font>
<!-- End Font Instances -->
</require>
<graphics>
<!-- Begin Global Graphic Settings -->
<main_display designed_for_size="800,620" show_at_size="800,480" menubar="fixed" RunInSystemTray="False" MinimizeToSystemTray="False"></main_display>
<background_image style="stretch" imagefilepath="Content\Images\Background_Air.png" page="0"></background_image>
<!-- End Global Graphic Settings -->
<button id="Left Front Fill" enabled="yes" function="trigger output" functionTargetID="Left Front Fill" vote="absolute" vote_opinion="on" vote_priority="low">
<images imagePrimary="Content\Images\ButtonUp.png" imageSecondary="Content\Images\ButtonUp.png" imageDisabled="Content\Images\ButtonUp.png" imagePushed="Content\Images\ButtonUp.png"></images>
<display size="56,56" location="100,212" page="0" z_order="0.0"></display>
<options imageScaling="stretch"></options>
<up_click up_click_function="trigger output" up_click_functionTargetID="Left Front Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Left Front Dump" enabled="yes" function="trigger output" functionTargetID="Left Front Dump" vote="absolute" vote_opinion="on" vote_priority="low">
<images imagePrimary="Content\Images\ButtonDown.png" imageSecondary="Content\Images\ButtonDown.png" imageDisabled="Content\Images\ButtonDown.png" imagePushed="Content\Images\ButtonDown.png"></images>
<display size="56,56" location="242,212" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Left Front Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Left Rear Fill" enabled="yes" function="trigger output" functionTargetID="Left Rear Fill" vote="absolute" vote_opinion="on" vote_priority="low">
<display size="56,56" location="100,412" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Left Rear Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Left Rear Dump" enabled="yes" function="trigger output" functionTargetID="Left Rear Dump" vote="absolute" vote_opinion="on" vote_priority="low">
<display size="56,56" location="242,412" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Left Rear Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Right Front Fill" enabled="yes" function="trigger output" functionTargetID="Right Front Fill" vote="absolute" vote_opinion="on" vote_priority="low">
<display size="56,56" location="500,212" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Right Front Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Right Front Dump" enabled="yes" function="trigger output" functionTargetID="Right Front Dump" vote="absolute" vote_opinion="on" vote_priority="low">
<display size="56,56" location="642,212" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Right Front Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Right Rear Fill" enabled="yes" function="trigger output" functionTargetID="Right Rear Fill" vote="absolute" vote_opinion="on" vote_priority="low">
<display size="56,56" location="500,412" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Right Rear Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<button id="Right Rear Dump" enabled="yes" function="trigger output" functionTargetID="Right Rear Dump" vote="absolute" vote_opinion="on" vote_priority="low">
<display size="56,56" location="642,412" page="0" z_order="0.0"></display>
<up_click up_click_function="trigger output" up_click_functionTargetID="Right Rear Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
</button>
<text_label id="Left Front Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_LeftFrontAir">
<font font_id="LED50" font_size="35"></font>
<display location="165,165" page="0"></display>
<config decimals="0" max_size="70,40"></config>
</text_label>
<text_label id="Left Rear Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_LeftRearAir">
<display location="165,365" page="0"></display>
</text_label>
<text_label id="Right Front Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_RightFrontAir">
<display location="565,165" page="0"></display>
</text_label>
<text_label id="Right Rear Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_RightRearAir">
<display location="565,365" page="0"></display>
</text_label>
</graphics>
<io>
<!-- Begin Fusion Brain Instances -->
<brain id="micerebro">USB\VID_04D8&PID_000C\6&17EF8D69&0&4</brain>
<!-- End Fusion Brain Instances -->
<!-- Begin Timer Setup -->
<timer id="input" interval="100"></timer>
<timer id="output" interval="100"></timer>
<timer id="gui" interval="50"></timer>
<timer id="logic" interval="50"></timer>
<!-- End Timer Setup -->
<!-- Begin Digital Output Instances -->
<iochannel id="Right Front Fill" port="1" brain="micerebro" type="digital_output">
<defaults defaultstate="off"></defaults>
</iochannel>
<iochannel id="Right Rear Fill" port="2" brain="micerebro" type="digital_output">
</iochannel>
<iochannel id="Left Front Fill" port="7" brain="micerebro" type="digital_output">
</iochannel>
<iochannel id="Left Rear Fill" port="0" brain="micerebro" type="digital_output">
</iochannel>
<iochannel id="Right Front Dump" port="8" brain="micerebro" type="digital_output">
</iochannel>
<iochannel id="Right Rear Dump" port="9" brain="micerebro" type="digital_output">
</iochannel>
<iochannel id="Left Front Dump" port="10" brain="micerebro" type="digital_output">
</iochannel>
<iochannel id="Left Rear Dump" port="11" brain="micerebro" type="digital_output">
</iochannel>
<!-- End Digital Output Instances -->
<iochannel id="RF Air" port="0" brain="micerebro" type="analogue_input">
</iochannel>
<iochannel id="LR Air" port="1" brain="micerebro" type="analogue_input">
</iochannel>
<iochannel id="LF Air" port="2" brain="micerebro" type="analogue_input">
</iochannel>
<iochannel id="RR Air" port="3" brain="micerebro" type="analogue_input">
</iochannel>
</io>
<logic>
<!-- Begin Logging Setup -->
<all_logging>
</all_logging>
<!-- End Logging Setup -->
<all_variables>
</all_variables>
<all_statements>
<parameter1>
<input order="1">
</input>
</evaluate>
</variable>
</parameter1>
</if>
<parameter1>
<input order="1">
</input>
</evaluate>
</variable>
</parameter1>
</if>
<parameter1>
<input order="1">
</input>
</evaluate>
</variable>
</parameter1>
</if>
<parameter1>
<input order="1">
</input>
</evaluate>
</variable>
</parameter1>
</if>
</all_statements>
</logic>
How's this?
will this monitor and stabilize itself?
I don't have the car with me to test this. I'll get the car back in about 2 weeks.
Steve
| Thread Tools |
| Display Modes |
Linear Mode
