10-19-2004, 03:25 AM
#16
Quote: Originally Posted by nickmig
This program is muting my WAV volume after exiting it...so I have to open up my sound properties and unmute wav....any fix or suggestions?
with frodoplayer1.09?
what I coded is SendMessage(frodoWnd,WM_USER + 1024,0,0);
what I want is to unmute!
please check with frodo for the correct number instead of 1024, I will correct it ASAP.
10-19-2004, 03:28 AM
#17
That was actually with 1.08.... I'll try it with 1.09 tom. morning after I get some sleep tonight
Compaq v6719 Athlon X2 tk-57
Xenarc 7" Dash Install, iGuidance w/ iGPS 500
HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
94.3% of all percentages are made up
10-20-2004, 09:12 PM
#18
yeah I just tested it today, I added it as the first app in frodoplayer.ini, then went and opened it up and it works, it just mutes the wave output after you exit. Then all the mp3's won't play and I have to open up my sound control properties to unmute the wav output. Although it mutes the wav on exit, if I open it back up the tv still has volume.... Love the program, just wish it worked for me.
10-20-2004, 09:18 PM
#19
are you just unmuteing the master volume and not the wav? I don't understand why the wav volume is being muted anyway.
10-20-2004, 11:39 PM
#20
checked
it is not my fault!
the reason could be:
frodoplayer mute itself before it open a APP which it doesn't know
in order to work with 1.09, I have coded my TVplugin to unmute frodoplayer before TVplugin quite by sending message to it.
10-20-2004, 11:44 PM
#21
I'm sorry, and you are....?
FrodoPlayer only mutes if you tell it to.
What command did you send ?
[H]4 Life
I'm a lesbian too.
I am for hire!
10-21-2004, 04:10 AM
#22
10-21-2004, 09:32 AM
#23
Damnit! I cant ever get any app to work with my TV/FM card! andts a BT878a chipset! Damn ebay bastards. Works perfectly with its own software too.
2007 Mazdaspeed 6
10-22-2004, 01:04 AM
#24
Well that's nice if you like telling frodo to go to the previous track.
You need to use WM_USER_FRODO_LOW + 11, to toggle mute on/off.
And you should first check to see what it is by getting the value
of : WM_USER_FRODO_HIGH + 7
where 0 = not muted, 1 = muted, 99 = N/A
WM_USER_FRODO_LOW = WM_USER + 1024
WM_USER_FRODO_HIGH = WM_USER + 1123
[H]4 Life
I'm a lesbian too.
I am for hire!
10-25-2004, 04:12 AM
#26
can be downloaded, see page1
10-26-2004, 03:45 AM
#27
improved to version 1.03.24
1.fix bug to work with radio
2.fix resumming pause of frodoplayer 1.09
please download new version TVplugin10324.zip on page 1
10-28-2004, 05:57 AM
#28
question is, whitch TV card and radio card there is a support for?
10-31-2004, 04:39 AM
#29
registration of Fly 2000 Tv
I got the tv to work using my flytv3000 tv card, however I have no plan of buying the software. Are there any other alternatives?
10-31-2004, 04:10 PM
#30
I figured out what my problem was...flytv has an option for muting your wav volume on exit, and for some reason it is checked by default.....RETARDED!
| Thread Tools |
| Display Modes |
Linear Mode
