11-25-2004, 07:00 AM
#31
i would like to have my own skin please. when can you make this skinable???
danon
[....99.9%]
[HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
[....99.8%]
[SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
[Working on] puttingBackEvrythg.
11-27-2004, 02:12 AM
#32
The EQ viz doesn't show everything else works fine. i realise you use winamp dlls, what should i do to make the eq show???
[....99.9%]
[....99.8%]
12-01-2004, 07:59 PM
#33
answered you on main thread
12-03-2004, 02:26 AM
#34
analyzer not showing
Axife FM Player Deluxe is working absolutely fine, no problem at all. i also have the arcade font installed, so the fonts are fine. what i am not getting is the analyzer (attached file "pic sample only.jpg")
i am using your fmplugin version 2.1.1.99
( http://www.carpcs.net/dragonbtv/FMp...plugin21199.zip)
[....99.9%]
[....99.8%]
12-03-2004, 02:32 AM
#35
Good grief! I am having a heck of a time trying to get all these programs and proper drivers running. I have the LifeView2000 TV/FM card and so far the only program that works with the latest WDM drivers is FlyTV 2000 (FM and TV work beautifully). Axife FM deluxe only works with an older driver (FlyTV 2000 still works) and Radiator doesn't seem to like anything.
DragonBTV, Would it be possible to use FlyTV2000 for all your FM/TV plugins or are you using Axife because of the timeshifting capabilities? Reason I ask is because both of them cost money!
12-03-2004, 02:53 AM
#36
the reason that I have to use AXFM is that Fly2000TV does NOT surport the rediator plugin on a lot of new TV cards for FM radio!
I have worked together with the author of Fly2000TV (a Rushen) for 2 weeks in order to solve it but failed at last
the SDK for AXFM is better than Fly2000TV on RADIO (of couse, it is radio only  )
12-03-2004, 02:57 AM
#37
1.install AXFM on it's DEFAULT directory, read above of my thread
2.read the help of AXFM and understand it's SKIN
3.after running my plugin once, try to start AXFM alone, you will find out there is a skin called "carPCuse"
4.change to that skin and check to make it works
12-03-2004, 03:16 AM
#38
I see...You have done great work. Now I just need to get all three programs running with my Flyview 2000 card (so far I can only get 2 of the 3 working, Radiator is being stubborn).
12-03-2004, 03:39 AM
#39
Well, I am a genious. To get Radiator, FlyTV2000, and Axife Fm to work on the LifeView 2000 TV/FM card you must use old driver version 20.51. Thanks DBTV!
12-03-2004, 06:43 PM
#40
finally made it to work, so the whole axfm window will become the eq analyzer, there's no way to drag it into position once it turned into the eq analyzer skin (the skin name i found is "carpcfinal") so i tried to put it into position several times.
how do you call it within frodoplayer ??? (maybe batchfile??), you can only open one external app within frodoplayer's radio under the settings and in your fmplugin case, axfm should open first before the fmplugin.
it's an awsome plugin you made btw
[....99.9%]
[....99.8%]
12-03-2004, 10:35 PM
#41
frodoplay start myplugin; myplugin start AXFM automaticlly, that's all
12-07-2004, 06:31 PM
#42
VENDOR - Centrafuse
dragonBTV: Is there any way to use your plugin in a non-graphical way? Like a remote interface? I wanted to add support to CENTRAFUSE, but want to be able to bulid the GUI on my end, like I do for radiator...
great looking program, everyone wants support for it added
david
12-07-2004, 06:37 PM
#43
My Village Called
david
He uses a component. Your job would be to find the C# equivalent of it.
12-07-2004, 07:54 PM
#44
david
the most simple way is to use command method of AXFM lite(free), a German had write a very detailed method for midiaporal
I used AXFM SDK
12-07-2004, 08:09 PM
#45
Ok Dragon I think I have a couple of problems trying to get your plugin to work
I have the font installed, Axife FM Player DEMO 2.39,Hauppage WinTV FM USB
I currently have the WinTV and Axife Player working perfectly w/timeshifting,EQ & visual ALL working
Now when I launch your plugin WITHOUT Axife I get please install the player?
I then started Axife first, then your plugin - it worked but theni have 2 versions of the radio playing - when i close out Axife I get nothing, no more sound - I also get no visuals - that spot is just blank
also Im missing my taskbar - it disappears when i click on your Plugin, the only way to get it back is to logout
what Im I doing wrong
thanks
| Thread Tools |
| Display Modes |
Linear Mode
