The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-09-2007, 05:58 AM   #1
My Photos: (0)
Rpm Pid
i'm really confused about the difference between the RPM and PID :
do they have the same parameter . i mean are the RPM params same as those of PID
many thanks
mohfa is offline   Reply With Quote
Sponsored Links
Old 04-09-2007, 07:15 AM   #2
joeyoravec's Avatar
Vehicle: 2003 Mustang GT
My Photos: (0)
From SAE J1930, PID means "parameter identification". It's an arbitrary identifier (number) assigned to one piece of diagnostic data.
From SAE J1930, RPM means "revolutions per minute". Under OBD-II the engine speed in revolutions per minute is parameter (hex) 0x0C.
joeyoravec is offline   Reply With Quote
Old 04-09-2007, 07:58 AM   #3
My Photos: (0)
So can i use the RPM params in OBD-II to get the ECU diagnostics as i do with PIDs , and is ELM 327 compatible with these RPM params
Old 04-09-2007, 10:19 AM   #4
joeyoravec's Avatar
My Photos: (0)
You can read the Engine Speed in revolutions per minute by asking for the correct parameter identification (PID). But there is no such "thing" as an RPM -- the acronym stands for (engine) revolutions-per-minute, and it's one of the data items (PIDs) available over OBD-II.
Old 04-10-2007, 03:10 AM   #5
My Photos: (0)
OH GOOD , i' so sorry joeyoravec i didn't mean RPM but PRN , sorry again
so what do u think about the confusion between PRN params and those of PID .
Sorry again
many thanks
Old 04-10-2007, 10:02 AM   #6
joeyoravec's Avatar
My Photos: (0)
From SAE J2178-2, PRN means "parameter reference number". It's a a two-byte number that identifies a specific parameter by name, physical unit, size in bytes, and scaling. This concept is compatible with the definition of a PID. This standard describes:
  1. A method to organize the identifiers into categories
  2. A way to describe the transformation from binary data to scaled physical units
  3. A reserved range so the numbers would be identical for any existing 1-byte OBD-II PIDs
  4. A few specific PRNs as example
The automakers have obviously read this standard. Most of them implement an enhanced/extended diagnostic mode with 2-byte identifiers, but few actually assign enhanced PIDs this way. Overall I don't feel that this section of the standard is very relevant today, or worth reading. Opinions may vary.
Old 11-16-2007, 11:53 PM   #7
My Photos: (0)
Any idea what protocol the RPM PID 1165 relates to? I used to think it was a proprietry FORD PID under J2190 but recent research has suggested it could be under the diagnostics of J2534.
Any help would be appreciated.
Thank you.
Mac powered 07 Mustang GT/CS
MacMustang is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
how to show car speed, rpm, etc. on lcd? Chroniccodez General Hardware Discussion 4 05-20-2006 06:38 PM
HELP PLEASE! Car just died...rpm is stuck 3onDubs General MP3Car Discussion 37 04-01-2006 09:40 PM
Mazda PID codes? coffeejolts Engine Management, OBD-II, Engine Diagnostics, etc. 0 01-16-2006 11:13 AM
Performance 10k RPM tach with shift lights and backlight pcgamer4life Classified Archive 2 01-16-2006 11:08 AM
Change volume with Engine RPM FunkDaMonkMan Software & Software Development 37 01-01-2005 11:27 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
