Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 04-30-2007, 09:52 PM   #1
rogergolf is an unknown quantity at this point
OBD Port on Cavalier not Working!
Greeting All and thanks in advance for the help you offer.
Problem: OBD Port on Chevy Cavalier 2000 not working, no output. This was verified by the Emission Inspection site. No output/display,,, no way of checking and completing inspection.
Lets assume, both units, (mine and the inspection stations) are working properly. I could not find a fuse which indicated it supported the OBD function. Maybe the Cavalier does not have an associated fuse, not sure, if you have any thoughts/experience on this pls share.
Prior to either:
1. Taking it to the shop for diagnostics of the OBD Port or ...
2. Taking the dash apart to trace the wiring harness....
I'm looking for some time saving advise.
I'm very willing to locate/replace the OnBoard Chip driving the OBD or whatever is necessary, just need some sound advice. Feel free to post or email me directly. Email and and posting is best option.
rogergolf is offline   Reply With Quote
Old 05-01-2007, 10:31 AM   #2
VENDOR - OBDPros
michbound is on a distinguished road
Most likely the lighter fuse/12 V accessory fuse is blown, this is a very common problem on GM cars, check that first.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
OBD port on '03 Volvo s40 johno12345 Engine Management, OBD-II, Engine Diagnostics, etc. 5 10-05-2009 09:10 AM
Need help setting port number in the widcomm 4 driver malkalm PhoneControl 4 07-04-2005 05:38 AM
wierd, slim dvd -> USB adaper MUST use ps/2 port for power... mattress General Hardware Discussion 6 04-05-2005 07:15 PM
Spliting power on a PS/2 port... Defiler General Hardware Discussion 3 02-27-2002 04:02 PM
COM port stopped working... need help! chris General Hardware Discussion 5 02-17-2001 12:39 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
