The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 05-13-2007, 03:57 PM   #1
OrangeSword's CarPC Specs
OrangeSword's Avatar
Vehicle: 2000 Nissan Frontier Crew Cab
My Photos: (0)
ELM Simulator/Emulator
I'm having trouble finding a program to simulate the data coming from an ELM on a PCs com port. I searched and found multiple references to a java app called jelmemulator, which is supposed to be here http://www.sophonix.com/downloads/jelmemulator.asp. However that site is dead. Does anyone know anywhere else to look or have a alternative solution?
OrangeSword is offline   Reply With Quote
Sponsored Links
Old 05-14-2007, 11:09 AM   #2
My Photos: (0)
What are you trying to achieve? If you just need to simulate data to an app that you are writing an easier way might be to instrument your read bytes from a binary file that has sample OBD II output from a live session.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 05-14-2007, 12:28 PM   #3
My Photos: (0)
I want to have a app siting on another computer that is sending OBDII data to my app on my computer via a com port. I don't have much experience programming using serial comunications, so I want to simulate the process and not have to sit in my car and program. I suppose I could just program a simulator app myself and have it send previously captured sample data from a file. I think I will try that, thanks.
Old 05-14-2007, 03:47 PM   #4
My Photos: (0)
You do not need two computers to simulate serial communication between two applications. As far as an ELM emulator app is concerned, I know ScanTool.net has one, but I am not sure if they would offer it for anyone to use (and it was extremely limited during testing)... however, it might get you started. Your best bet is probably just to pick up some hardware.
Joel Konecny
Digimoto OBDII Diagnostics
digimotojoel is offline   Reply With Quote
Old 05-24-2007, 06:45 AM   #5
Vehicle: 2003 Ford BA Falcon XR8
My Photos: (0)
I'd find a simulator useful as well. The only way to get valid responses out of an ELM is to have it plugged in. Having a simulator would sure help the battery-life on my car while I'm programming....
Certainly, providing an effective emulator would encourage more developers to add code into their scan tool software.
Lukeyson
Lukeyson is offline   Reply With Quote
Old 05-24-2007, 02:24 PM   #6
joeyoravec's Avatar
Vehicle: 2003 Mustang GT
My Photos: (0)
I've written a simulator that works on J2534 devices. I'm willing to make it an open source project, but I haven't had time to post it on sourceforge or anywhere like that. Feel free to send me an IM or email if you're interested.
joeyoravec is offline   Reply With Quote
Old 05-31-2007, 06:16 PM   #7
My Photos: (0)
I believe I've learned enough in the past few weeks to write a simple simulator for myself. Does anyone have any good suggestions for a virtual serial port program? I've already found a few, but if anyone knows about a killer one, please share.
Old 06-04-2007, 01:23 AM   #8
My Photos: (0)
Here you hope hope this helps
http://www.elmelectronics.com/ElmUse.../ELMULATOR.zip
tom_say is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
OBDII / Elm MPG meter. Almost working but not quite! stevieg Engine Management, OBD-II, Engine Diagnostics, etc. 104 06-30-2008 07:34 PM
Advice for system?? sseverett Engine Management, OBD-II, Engine Diagnostics, etc. 23 01-11-2007 05:09 PM
Can ELM scantools Turn Off Service Light softneed Engine Management, OBD-II, Engine Diagnostics, etc. 3 07-07-2005 03:15 PM
Autoenginuity Elm Chip Based? RJP350Z Engine Management, OBD-II, Engine Diagnostics, etc. 0 04-13-2005 03:49 PM
Best ELM software slboytoy Engine Management, OBD-II, Engine Diagnostics, etc. 3 06-15-2004 07:28 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
