The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 05-30-2007, 07:06 PM   #1
OrangeSword's CarPC Specs
OrangeSword's Avatar
Vehicle: 2000 Nissan Frontier Crew Cab
My Photos: (0)
C# Application using OBDPro scantool
I've written a c# app that reads data from my cars OBD port using the OBDPro scantool. My program loops through my "Command" objects and sends commands to a serial port connection object. I'm only sending 4 commands on each loop; Speed, RPM, CoolantTemp and Throttle position. After all four have been sent the application sleeps for 1 seconds and resumes the loop. Meanwhile I have an event listener on the Serial Port object that fires anytime data appears on the serial ports buffer. When it does I read all the characters until I find a carriage return and convert that hex string to a readable integer value and update my windows form. However whenever I send 4 or more commands on each iteration I often get "NO DATA" or ? from the cars OBD port for at least one of the commands. Before talk to the OBD port I first send ate0 and atl0 to suppress echoes and linefeeds. The baud rate is also @ 128000. ScanTool.net doesn't seem to behave this way. Can anyone give some pointers on how to make the responses more reliable? Here are a few snippets of my code:
My control loop:
Code:
private void BeginControlLoopThread() { while (true) { foreach (OBDCommand obdCommand in mOBDCommandRepository.OBDCommands) { mSerialPort.WriteLine(obdCommand.Mode + " " + obdCommand.PID); mMainWindow.WriteToInputLogDisplay(obdCommand.Mode + " " + obdCommand.PID); } Thread.Sleep(1000); } }
My event listener:
Code:
private void SerialPort_DataReceived(object sender, EventArgs e) { string response = ""; try { response = mSerialPort.ReadTo("\r>"); } catch (Exception exception) { // do nothing, exit // exception.Message.ToString(); return; } response = response.Trim(); mMainWindow.WriteToOutputLogDisplay(response); if (response.StartsWith("4")) { string[] translatedResponse = mOBDCommandRepository.TranslateResponse(response); SendToUI(translatedResponse); } }
OrangeSword is offline   Reply With Quote
Sponsored Links
Old 05-30-2007, 07:13 PM   #2
My Photos: (0)
If an admin thinks this is better suited in the Software Development, please move it there. I didn't see an dedicated OBD section over there and I wanted to make sure the people using OBDPro see this.
Old 05-31-2007, 06:55 AM   #3
My Photos: (0)
OrangeSword,
In your control loop thread you should wait for the ">" prompt before sending another command. The OBDPro can buffer serial data while executing a previous OBD Command but ocasionally it will not be able to keep up with buffering serial data and processing the OBD command at the same time.
One way to do this is create a boolean promptSeen. Set this to true when you read a ">" on the serial port handler, and only send a new OBD command when promptSeen == TRUE
hth
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 05-31-2007, 11:13 AM   #4
My Photos: (0)
I am not getting a "Buffer Full" message back so I don't think the buffer is full.
But anyway following your advice, I've changed the code to this:
Code:
private void BeginControlLoopThread() { bool promptFound; ; bool responseEndFound; string response; while (true) { foreach (OBDCommand obdCommand in mOBDCommandRepository.OBDCommands) { response = ""; promptFound = false; while (!promptFound) { try { mSerialPort.ReadTo(">"); mSerialPort.WriteLine(obdCommand.Mode + " " + obdCommand.PID); mMainWindow.WriteToInputLogDisplay(obdCommand.Mode + " " + obdCommand.PID); promptFound = true; } catch (Exception e) { // Prompt was not found, do nothing } } responseEndFound = false; while (!responseEndFound) { try { response = mSerialPort.ReadTo("\r"); response = response.Trim(); mMainWindow.WriteToOutputLogDisplay(response); if (response.StartsWith("4")) { string[] translatedResponse = mOBDCommandRepository.TranslateResponse(response); SendToUI(translatedResponse); } responseEndFound = true; } catch (Exception e) { // Command not finished was not found, do nothing } } } Thread.Sleep(1000); }
Potentially I will have a large number of responses to loop through and it might take awhile to finish the loop if I have to wait for every response. Is there a way to get multiple responses back at one time? Like ALL of the data in Mode 01? Am I doing it the most efficient way, is what I am trying to get at.
Old 05-31-2007, 07:02 PM   #5
My Photos: (0)
Sorry I should have made it a bit more clear....
It's not the OBD buffer that is full, but when getting data from the vehicle bus there are times when the interface needs to shut off processing the serial port interrupts, this means some characters would be dropped...
The ">" char signals the PC that the OBDPro is done executing the command and is now ready to accept additional commands. To make sure you can issue the command immediately when the interface is ready one way would be to send the data right out of the serial data recieved handler. Let me find the code that I use to test the interface and I can send you something as an example...
Paul
www.obdpros.com
Old 05-31-2007, 11:58 PM   #6
My Photos: (0)
Thanks. I appreciate it. One other question, is the "NO DATA" and "?" results terminated by a carriage return?
Old 06-19-2007, 09:29 PM   #7
Vehicle: 2005 Mazda 6s
My Photos: (0)
Keep in mind that if you are reading up to the prompt, you will not be able to use this when looking at streaming data (such as the ATMA mode) since it does not produce a prompt after each line. Using the ReadLine method and keeping line breaks on (ATL1) will solve this. You can always trim the prompt off the front of the response line.
Also, for those looking to use VB.NET you will need to use the Write method and append a carriage return to the command. The WriteLine method does not work with this in VB.NET.
I'll be posting a demo app on obdpros.com forums in a day or so. Just something basic to help beginners get started. My nick on obdpros.com is Deviation....
Yes. If you leave line breaks on.
2005 Mazda 6s
2002 GMC Envoy SLT
Digital Deviation
Addict is offline   Reply With Quote
Old 06-25-2007, 07:41 AM   #8
My Photos: (0)
hi have you finished this yet
aslaughter is offline   Reply With Quote
Old 06-25-2007, 07:02 PM   #9
My Photos: (0)
No not yet. I'm not really building it for distribution, but here is the code I have so far if you are interested in that:
Code:
using System; using System.Collections.Generic; using System.Text; using System.Collections; using System.IO.Ports; using System.Configuration; namespace OrangeSword.FrontierDash.ObdReader.BusinessLogic { /// <summary> /// Represents a OBD device such as a OBDPro. /// </summary> public class ObdDevice { private string portName; private int baudRate; private SerialPort serialPort; /// <summary> /// Initializes a new instance of the <see cref="ObdDevice"/> class. /// </summary> public ObdDevice() { portName = ConfigurationManager.AppSettings["portName"]; baudRate = Convert.ToInt32(ConfigurationManager.AppSettings["baudRate"]); Connect(); } /// <summary> /// Connects this instance. /// </summary> private void Connect() { serialPort = new SerialPort(portName, baudRate); serialPort.Open(); serialPort.ReadTimeout = 1000; serialPort.NewLine = "\r"; } /// <summary> /// Disconnects this instance. /// </summary> private void Disconnect() { serialPort.Close(); } /// <summary> /// Initializes this instance. /// </summary> public void Initialize() { Reset(); SendAtCommand("ate0"); SendAtCommand("atl0"); } /// <summary> /// Sends the obd command. /// </summary> /// <param name="obdCommand">The obd command.</param> /// <returns>The response to the OBD command from the OBD device.</returns> public string SendObdCommand(ObdCommand obdCommand) { string response = ""; bool promptFound = false; bool responseEndFound = false; while (!promptFound) { try { serialPort.ReadTo(">"); serialPort.WriteLine(obdCommand.Mode + " " + obdCommand.PID); promptFound = true; } catch (Exception e) { // Prompt was not found Console.WriteLine("Prompt not found: " + e.Message); } } while (!responseEndFound) { try { response = serialPort.ReadTo("\r"); response = response.Trim(); if (response.StartsWith("4")) { responseEndFound = true; } } catch (Exception e) { // Carriage Return not found Console.WriteLine("Carriage Return not found: " + e.Message); if (response == "NO DATA") { responseEndFound = true; } } } return response; } /// <summary> /// Sends the AT command. /// </summary> /// <param name="atCommand">The AT command.</param> /// <returns></returns> public string SendAtCommand(string atCommand) { string response = ""; bool promptFound = false; bool responseEndFound = false; while (!promptFound) { try { serialPort.ReadTo(">"); serialPort.WriteLine(atCommand); promptFound = true; } catch (Exception e) { // Prompt was not found Console.WriteLine("Prompt not Found: " + e.Message); } } while (!responseEndFound) { try { response = serialPort.ReadTo("\r"); response = response.Trim(); responseEndFound = true; } catch (Exception e) { // Carriage Return not found Console.WriteLine("Carriage Return not found: " + e.Message); } } return response; } /// <summary> /// Resets this instance. /// </summary> public void Reset() { serialPort.WriteLine("atz"); } } }
Old 08-02-2007, 02:34 PM   #10
impala454's Avatar
Vehicle: 2006 Chevrolet Silverado
My Photos: (0)
Hey guys, new here but been lurking a few weeks. I am about to start a project as well in C#.net, and Orange I think that code is a great start, I had no idea that there's a ports namespace (just looked it up and it looks like it's new to framework 2.0+). upon just a quick msdn read, it looks like the SerialPort class has event handler delegates, so that would seem to be your best bet, rather than waiting for a certain response, you could just use the SerialDataReceivedEventHanlder delegate to invoke a callback function. I'm going to start messing around with this tonight so if I make any progress I'll be sure and post it up here.
impala454 is offline   Reply With Quote
Sponsored Links
Old 08-02-2007, 06:24 PM   #11
My Photos: (0)
Impala,
You have the right approach with the event based setup, I had mentioned to orange that I would throw up some code that I use to test with but it is in such lousy shape that I am afraid to share and just have not had time to clean up.
Since there seems to be some interest I will plan on cleaning it up and posting it if that helps someone
Paul
www.obdpros.com
Old 08-02-2007, 09:38 PM   #12
impala454's Avatar
My Photos: (0)
Well it's definitely more fun to look at dirty code than no code
here's a quick file I put together, doesn't quite work but you get the idea. I just got my feet wet with this tonight so hopefully I'll get the hang of it after a while.
Code:
using System; using System.IO.Ports; using System.Text; using System.Threading; using System.IO; namespace TestObdScanner { public class ObdDevice { private string PortName; private int BaudRate; private int ReadTimeOut; private SerialPort Port; public ObdDevice(string portName, int baudRate) { PortName = portName; BaudRate = baudRate; ReadTimeOut = 1000; Port = new SerialPort(PortName, BaudRate); } public ObdDevice(string portName, int baudRate, int readTimeOut) { PortName = portName; BaudRate = baudRate; ReadTimeOut = readTimeOut; Port = new SerialPort(PortName, BaudRate); } public bool Connect() { if (Port != null) { try { Port.Open(); Port.DataReceived += new SerialDataReceivedEventHandler(Port_DataReceived); } catch (Exception OpenExcep) { Console.WriteLine(OpenExcep.Message); return false; } } else { Console.WriteLine("Error: Tried to connect with a null port"); } return true; } public void TestAllPids() { int MaxDecimalPid = 78; StringBuilder Command = new StringBuilder(6); for (int i = 1; i <= MaxDecimalPid; i++) { Command.AppendFormat("01 {0}", i.ToString("X2")); Console.WriteLine(Command.ToString()); WriteLogFile(Command.ToString()); Port.WriteLine(Command.ToString()); Thread.Sleep(ReadTimeOut); Command.Remove(0, Command.Length); } } private void Port_DataReceived(object sender, SerialDataReceivedEventArgs args) { string RawData = Port.ReadExisting(); // Update some publicly accessible data structure to make this useful Console.WriteLine(RawData); WriteLogFile(RawData); } private void WriteLogFile(string message) { StreamWriter sw = new StreamWriter("log.txt", true); sw.WriteLine(message); sw.Close(); } } }
with the usage of the class like:
Code:
using System; using TestObdScanner; namespace ObdConsoleTest { class Program { static void Main(string[] args) { ObdDevice dev = new ObdDevice("COM1", 9600); if (dev.Connect()) dev.TestAllPids(); } } }
the callback is happening, just not seeing the data I'm expecting to see, the log ends up repeating the command sent.
Old 08-03-2007, 10:39 AM   #13
impala454's Avatar
My Photos: (0)
hmm maybe an echo off command will prevent that and make it work... will have to try that when I get home.
Old 08-05-2007, 02:42 AM   #14
My Photos: (0)
Keep going
hey guys.. nice great coding i wish you all the success.I'm a beginner and need some help.im trying to type my own code using a language called Tiger basic but i don't know how to initialize the ISO 9141 protocol if anyone can help me it would be great,my email is (m-samehsabry@peparab.com)
sameh is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
How do I integrate my application with RR ? guino RR FAQ 0 09-23-2006 08:38 PM
Notifying child application of Hibernation wakeup mullaly Road Runner 2 04-24-2006 03:44 AM
How to embbed any Application in RR ? guino RR FAQ 0 03-20-2005 12:35 PM
Beta-Testing External Application Code CarComp Media Engine 2 02-17-2005 10:42 PM
embedded GPS application problem Bokky Centrafuse 4 01-23-2005 12:44 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
