The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 06-16-2007, 12:02 AM   #1
cockie55's CarPC Specs
Vehicle: Landrover
My Photos: (0)
Help OBD1 Scanner/Interface???
I am trying to track down a OBD interface/scanner manufacturer/supplier who has a interface unit that can decode my OBDI data via a serial connector.
No luck so far ...I would be very grateful if someone could point me in right direction ???
cockie55 is offline   Reply With Quote
Sponsored Links
Old 06-16-2007, 12:03 AM   #2
P3D4T0R's CarPC Specs
P3D4T0R's Avatar
Vehicle: 1987 GMC Jimmy
My Photos: (8)
This site has a good free program and tells you how to make your own http://winaldl.joby.se/ But if youd like to buy a kit or a pre built cable with tons of good free software plus some not so free software check out this site http://www.aldlcable.com/sc/toplevel.asp?cat=0
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (The PlowPuter)
P3D4T0R is offline   Reply With Quote
Old 06-19-2007, 10:02 AM   #3
Vehicle: Landrover
My Photos: (0)
Thankyou
Thanks Mr PTOR...great links...you saved my a.se. I now know the difference between what is in my 13 year old OBDI truck and current OBDII. Ironicaly it seems I will be able to get live engine data and default codes out of my prehistoric ECU with a $30 cable and some freeware whereas OBDII requires big spend $ and many potential conflicts.
Thanks again
Old 06-20-2007, 12:43 PM   #4
My Photos: (0)
http://www.mp3car.com/vbulletin/engi...ml#post1080254
I hope that help ou to write your own software to decode data stream from ALDL connector
EfimoMax is offline   Reply With Quote
Old 03-06-2008, 01:12 PM   #5
My Photos: (0)
Thanks again
I have the same problem how do i? exactly what do i need to read the codes on a pc? and did the responce from mr ptro work?
jayj200 is offline   Reply With Quote
Old 04-21-2008, 02:01 PM   #6
My Photos: (0)
I got the aldl cable from aldlcable.com it worked minamaly (not very damn good) I returned it today!
Old 04-23-2008, 02:02 AM   #7
My Photos: (0)
You most likely did not have the software setup correctly or did not follow the instructions. My cable from aldlcable.com has worked great and I have hooked up to a number of cars with TTS Datamaster and EFILive, both free packages that are awesome. These GM OBD1 cars were far ahead of everyone at the time for data logging and tuning.
blazerdude is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
OBD1 - Options & Solutions Please !! CivicDisturbance Engine Management, OBD-II, Engine Diagnostics, etc. 35 06-25-2008 11:10 PM
How to read OBD1? Lowtechguy Engine Management, OBD-II, Engine Diagnostics, etc. 1 05-21-2008 02:40 PM
OBD1 1995 Silverado geekazoid Engine Management, OBD-II, Engine Diagnostics, etc. 7 03-12-2008 05:41 PM
stupid OBD1 interface. turbochris General MP3Car Discussion 5 06-03-2007 03:52 PM
obd1 obd2 harness? dannylad Engine Management, OBD-II, Engine Diagnostics, etc. 0 10-06-2006 06:31 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
