Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-29-2007, 01:55 PM   #1
PPE
PPE's Avatar
PPE is on a distinguished road
PCMSCAN v2.3.0 has been released.
Version 2.3.0, June 29th 2007
This new release adds support for log file bookmarks and custom audible and bookmarked alerts.
If you notice the engine misfiring or some other problem, using the log file bookmarks you can just reach over and press F6 to add a bookmark into the logged data that is being recorded. Then you can come back at any time and see exactly where the bookmark is and view the surrounding frames of data to analyze the problem.
The new alerts system allows you to configure the software to monitor any parameter(s) you like. When the specified conditions are met, the software will automatically play a sound (to warn you if you are driving) or insert a bookmark for you into the logged data that is being recorded. So, for example, if you are seeing power loss at high RPM under full throttle conditions, you can set up an alert that monitors RPM and throttle position so that when RPM is above 4000 and throttle position is above 80% you can have the software automatically add a bookmark and/or play a sound. The software has many sound files included with it, or you can supply your own.
Click here to download a free demo and see a full list of changes.
If you are a new to PCMSCAN, click here to purchase your own copy. If you are an existing customer, this is a free update.
Brian @ Palmer Performance Engineering, Inc.
http://www.palmerperformance.com
PPE is offline   Reply With Quote
PCMSCAN integrated into RR sandworm Engine Management, OBD-II, Engine Diagnostics, etc. 20 07-21-2009 09:54 PM
PCMSCAN v2.1 has been released. PPE Engine Management, OBD-II, Engine Diagnostics, etc. 0 01-22-2007 06:00 PM
PCMSCAN + Subaru, which adapter benetton Engine Management, OBD-II, Engine Diagnostics, etc. 22 11-28-2006 02:32 AM
New Lilliput drivers released! RS200Z LCD/Display 1 06-07-2006 10:57 PM
ANNOUNCEMENT: Zehnder LCD Plugin v 6.0a released CrazyLittle Software & Software Development 0 03-04-2003 08:51 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
