Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-08-2007, 02:37 AM   #1
xgalaz is an unknown quantity at this point
2002 Chevy Tahoe + P0174
I am currently having problems with my 2002 Chevy Tahoe with a lean bank 2 code, P0174/P0171. I have cleaned the MAF sensor, changed the fuel filter, regulator and fuel pump/module because the fuel pressure was very low. Now, my fuel pressure is reading the proper 60 psi as required by the maintenance manual. I have checked all the vacuum lines and hoses to include intake gaskets as other forums have suggested-no leaks were noted. The vehicle now starts and runs great; but, every-now-and-then it does not want to start. The check engine light does not come back on but I am still having the intermittent starting problem. What else could this be before I start looking at fuel injectors?
xgalaz is offline   Reply With Quote
Old 10-09-2007, 07:15 AM   #2
Uraijit's Avatar
Uraijit is infamous around these parts
A little delayed, but I ran across this post searching for something else. If you're running lean on bank 2, but not on bank 1, try replacing the O2 sensor, that's the most likely culprit.
Bank 1 is before the Cat, bank 2 is after. Generally, you won't get a "lean" warning if it's the Cat, so it's probably just a bad sensor.
Greedy
-Adj.
Anybody who makes significantly more money than you do.
The Hoe-Puter Worklog
Progress (Phase one):
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Uraijit is offline   Reply With Quote
Old 11-22-2007, 02:50 AM   #3
warscout2 is on a distinguished road
i have had this code on my trans am bank 2 means left side of your engine and its most likly just your O2 going bad
warscout2 is offline   Reply With Quote
Chevy Tahoe - Rear AC/Heat control unit asong31 General MP3Car Discussion 1 10-07-2007 03:13 AM
New Stereo for 2002 Chevy Tahoe laker160th Car Audio 3 02-16-2007 09:36 PM
Redesigning the 2002 Chevy Suburban A/C Controls TheDeepFryedBoo Hardware Development 0 12-21-2006 02:12 PM
Chevy Tahoe Stock Amp?? asong31 Car Audio 5 12-14-2006 01:35 PM
Unlock Chevy Tahoe Touch Screen OEM GPS gderamel GPS 7 09-12-2005 09:20 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
