The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 07-28-2007, 01:41 PM   #1
flodulv's Avatar
Vehicle: 1992 VW Caravelle
My Photos: (5)
Odb-i (odb-1)
Looking for ODB-I hardware.
Need this to connect computer and car together.
Also need information about software.
my car is VW Caravelle / VAN / Vanagon og transporter 1992 mod.
It's a diesel engine.
Can somebody help me, need this to use on Road Runner og other frontend.
Thanks...
flodulv is offline   Reply With Quote
Sponsored Links
Old 07-28-2007, 09:30 PM   #2
Vehicle: 2004/Honda/Civic
My Photos: (0)
Unhappy
Thanks...
Sorry, but unfortunatly OBD1 wasn't a heavily regulated communications protocol by the U.S. or by SAE. It's going to be a crap shoot as to which one it uses and probably won't be supported by any of the current available hardware. But their is a slim chance (1 in a goggaplex) that it might be running ISO 9141-2 or KWP2000.
Boombox is offline   Reply With Quote
Old 07-29-2007, 05:24 AM   #3
flodulv's Avatar
My Photos: (5)
Hardware for VW 1992...
Is there anywhere i can find some cable / hardware to connect my car to a computer... USB or Serial port.
I also think this is called Eurovan... but there is no ODB-II on this car.
Only ODB-I (ODB-1)
There must be someone that know if there is any hardware for this.
Old 07-29-2007, 05:49 AM   #4
Vehicle: '95 / Mitsubishi / Pajero
My Photos: (0)
You could try Evoscan, http://www.limitless.co.nz/EvoScan/
Although designed for Mitsubishi, the connector is available for JOBD, also I believe OBD1
brodgar is offline   Reply With Quote
Old 07-30-2007, 08:15 AM   #5
flodulv's Avatar
My Photos: (5)
No ODB-1 on that site.
Cannot find anyway.
hope there is some other that know...
Old 10-13-2007, 05:05 PM   #6
My Photos: (0)
If you are still looking for an OBD I connector, I have one that connects to a computer via USB connector. I purchased it for a car, but the car ended up having an OBD II connector.
Contact me and let me know if you still need one.
HearseNurse is offline   Reply With Quote
Old 01-12-2008, 04:18 AM   #7
toyotatyrant's Avatar
My Photos: (0)
OBD 1 vehicles that don't have a data stream require whats called a "break-out-box" in order to get raw data traveling between the vehicle's sensors and the car's ECU/ECM. Breakout boxes are basicly vehicle specific test junctions that a tech would screw between the vehicle harnes and the ECU and give you easy access test points for the vehicles ECM (Have done it many times and I don't miss it at all). Basiclly you use it to get meter or ocilloscope readings at the ECU/ECM without backprobing. Break-out-boxes are expensive as the dickens, and are super bulky. I never seen one intergrated with a pc but maybe someday. OBD-2 onboard systems helped reduce the need for the dreaded break-out-box by leaps and bounds. But when it comes to an old OBD-1 car that don't have data streams, I don't know what else to tell you with this one . I'm not saying it can't be done with todays technology though. It just might not be easy.
toyotatyrant is offline   Reply With Quote
Old 01-12-2008, 12:10 PM   #8
My Photos: (0)
Thanks...
Not sure what ECU's you would be looking to gain data from on this vehicle?
UKOBD is offline   Reply With Quote
Old 01-14-2008, 02:12 AM   #9
CocoVFR's CarPC Specs
Vehicle: 1991 Audi S2 Coupé
My Photos: (0)
For every VW or Audi since 1991...
Try Vag-Com for all VW or Audi.
It works for my 1991 Audi S2.
You probably need an X2 adaptator to connecte your car to vag-com (as me)
CocoVFR is offline   Reply With Quote
Old 01-15-2008, 02:53 PM   #10
My Photos: (0)
Its an early diesel though.... No ECU?
Gareth
Sponsored Links
vB code is On
Trackbacks are Off
ODB II and GM DIC cw95403 Engine Management, OBD-II, Engine Diagnostics, etc. 14 04-08-2008 01:59 PM
odb 2 for astra SRI stevends Engine Management, OBD-II, Engine Diagnostics, etc. 1 03-16-2007 02:40 AM
VW Golf TDi MK4 2002 ODB cable confusion - which one is the right cable? f1lby Engine Management, OBD-II, Engine Diagnostics, etc. 3 02-19-2007 07:19 AM
Relationship between ODB and CanBus Cruizer Engine Management, OBD-II, Engine Diagnostics, etc. 4 06-03-2006 11:45 PM
Newbie question about ODB I and II Nokia6600 Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-24-2004 10:59 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
