The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 07-28-2007, 02:17 PM   #1
My Photos: (0)
Altima USB cable to computer.
Hey, unlike everyone else here. I think outside of the box. I am going to be installing a USB port in my car that directly connects to the port by my feet.
So, I need to know which wires relate to what. In other words, those USB cables. I need to know how they make them.
Can anyone that has one check it out for me. IT IS REALLY REALLY REALLY EASY TO FIGURE IT OUT GUYS.
So no smart *** replies like go buy it.
if you test resistance on one connection to the other, you should be able to map which wires go where without taking the cord apart.
Thank you in advance.
I plan on using software on a XP or vista based system to pull data from my car so I can monitor it. 99.9% OF ALL NEW NOTEBOOKS DO NOT have serial connections. so no, I can't use serial.
runcool is offline   Reply With Quote
Sponsored Links
Old 07-28-2007, 02:33 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Pin Name Description
1 VCC +5 VDC
2 D- Data -
3 D+ Data +
4 GND Ground
It really would be easier to just buiy one, but there's the pinout for a USB port. However, to extent them, take an existing set of USB headers, chop 'em in half, and extend with Cat5 cable. 4 pins per USB port... 8 wires in a Cat5 cable... It works out nicely, methinks.
Knock your socks off.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-28-2007, 02:56 PM   #3
My Photos: (0)
Oh, I know how USB cables work. sorry. I needed to find out which pins those go to on the car itself. Also, do I need a resister to lower the voltage to 5 volts??? or is it already setup that way?
I'll be hooking up a female connector in my center console then connecting the other side **using the wire splicing method** to the dataport. Trying to do it so no one can see that I did it.
But, I have everything in my center console already.. so trying to stay in that area. got two 120V outlets, controls for any lights I have in my car, then outside lights on another switch, blablabla.
Old 07-28-2007, 10:08 PM   #4
My Photos: (0)
Ok, I am confused now, since you talk about lowering the voltage and getting data from the Car. Do you want to read OBD II data from the vehicle? You cannot just connect the USB cable to the OBD II connector to do that, you need a protocol converter since the USB protocol is not what the OBD II connector outputs.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 07-28-2007, 10:18 PM   #5
Lithoss's CarPC Specs
Vehicle: '06 Impreza WRX TR
My Photos: (0)
Hey, this guy thinks out of the box unlike the rest of us. Lets just let him figure it out himself, especially since he's making no sense.
You also can't just use a resistor to drop the voltage. Unless you know exactly how much current your system will be drawing, that is, which is pretty hard to do with a computer.....
Lithoss is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
USB DVD/RW issues kamikaze2112 General Hardware Discussion 1 08-04-2006 10:43 AM
16FT USB Cable Extension, Passive Vs Active? mattress General Hardware Discussion 3 05-21-2006 11:45 PM
For Sale! 2 years of car computer stuff, EVERYTHING MUST SELL Cobelli Classified Archive 77 08-23-2005 09:16 AM
Got my IDE > USB cable today. d_sellers1 Newbie 3 10-05-2004 12:40 PM
problem with my usb to ide cable. high speed usb drive? DSM97RS General Hardware Discussion 14 05-19-2004 12:10 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
