I have the OBDII connection. Can somebdy tell what are the string shows
MPG(I heard some car does give MPG through OBDII connector).
Also What are the strings for Odometer reading.
MPG is a calculated field I'm afraid, if you are looking for this type of data probably best to go for a ScanGauge - they've done all of the work for you!
