09-09-2007, 12:55 PM
#1
Vehicle: 03 Focus Zetec
OBD Gauges required for RR
Hey Guys...can anyone help me out.
I've got my ELM320 working in various OBD software programs...BUT
I need a nice set of analogue gauges I can embed into a RoadRunner screen.
Has anyone got anything I can use ? (apart from OBD-DIAG)
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
09-10-2007, 04:40 AM
#2
I think it's time to integrate OBDII support in RoadRunner. Or write a plugin to it. Then anyone will use custom flash gauges as for GPS speedo and etc.
09-10-2007, 05:19 AM
#3
Perhaps I should be brave and put that to the RR Forum
09-10-2007, 11:21 AM
#4
Have you seen our DashCommand™ software? It was designed for just this purpose.
Also, the mp3car.com community can use the "mp3car" coupon code to receive a discount from our online store.
09-10-2007, 02:53 PM
#5
Thank You, I'm very greatful for that Info. I'll check out your program asap.
09-10-2007, 10:34 PM
#6
Ok, great! If you have any questions or problems, don't hesitate to post up and ask me about them. I'd be more than happy to help you get it set up and running.
-Brian
09-11-2007, 03:06 AM
#7
-Brian
I've installed Dashcommand (registered) on my laptop to test it out and familiarise myself with it. When I hit connect it just sits there saying "connecting" If I touch anything the Dashcommand window goes blank with a "not responding" message in the window title bar.
Where is the configuration file/screen to confirm com port etc. ??
I have confirmed the correct operation of my ELM320 (V2) by running OBD-DIAG successfully. My 320 is connected by USB, which has been set to com1.
HELP !
09-11-2007, 09:01 AM
#8
PPE - out of curiousity what did you use to create those gauges? I'm guessing some of the tools from Dundas or Chart FX?
09-11-2007, 10:28 AM
#9
HELP !
Hi Wizz,
Can you please download the demo version of PCMSCAN and see if it also has trouble connecting. Both applications share the same code for connecting to the OBD-II port, so I'd like to determine if there is a problem there, or somewhere else.
-Brian
09-11-2007, 10:30 AM
#10
Those gauges are completely custom. They are built using our custom DashXL™ technology. Feel free to download either PCMSCAN™ or DashCommand™ and try out the dashboard editor. You can find the online help for the dashboard editor here: http://www.palmerperformance.com/products/dashxl/help
-Brian
09-11-2007, 12:51 PM
#11
Hi Wizz,
-Brian
PCMSCAN doesn't work either. I hit connect and it just sits there saying "opening OBD-II connection" , have to Ctl/Alt/Del to get out of the program.
If I go to OBD-II settings..the interface is set to ELM...I adjust the Protocol manually to J1850-PWM.
BUT...I can't set a Com port because it's greyed out and displays N/A. ????
FYI... I ran EasyOBDII both before and after trying to run PCMSCAN, just to make sure the ELM320 was connected and functioning correctly.
I also checked the bios version on the 320....if I send it atz it returns ELM320 v2.0.
Whats happening ??
09-11-2007, 01:12 PM
#12
Whats happening ??
You don't need to manually set the COM port with our software. It will automatically detect it for you.
You don't have any Bluetooth COM ports on your computer do you? The only time I've seen hangs like this is when the Bluetooth stack is trying to do device discovery and it sometimes takes FOREVER. If you do have Bluetooth COM ports, can you try disabling them in the device manager and let me know if that is the problem?
-Brian
09-11-2007, 03:03 PM
#13
-Brian
Yes, I do have bluetooth on my laptop which I will uninstall. But I also have bluetooth on my carpc which is essential because I use it with Phoco for phone integration.
Bit late here in the UK.....I'll let you know how I get on tommorrow.
09-11-2007, 04:54 PM
#14
I'm not suggesting that you disable the entire Bluetooth stack. I'm just suggesting that you go into the device manager and disable any unused Bluetooth virtual COM port devices. If the virtual COM port device is in use, then it wouldn't cause this problem anyways. Please let me know how it goes.
-Brian
09-12-2007, 04:57 AM
#15
-Brian
I uninstalled the bluetooth on my laptop. This is no big deal because I was only using a bluetooth dongle to link to a BT sat receiver for another project, and the laptop was a testbed for your software, so everything can be restored, if required. Once the BT software was gone DashCommand worked.
I then installed it on my carpc, and despite BT being present, it also worked on there too.
The only problem I have now (which is not yours !) is my CPU temperature goes through the roof...probably because of the additional ELM device and I had to add a USB hub because I ran out of USB ports.
Maybe there is such a thing as a USB to serial connector....I'll have to look on Ebay.
Thanks for your help.
Wizz
| Thread Tools |
| Display Modes |
Linear Mode
