The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 09-15-2007, 12:34 PM   #1
Mcnovy's Avatar
Vehicle: 2003 Citroën C3
My Photos: (0)
Arrow OBD and Citroen from 2003 (Diesel)
Hi guys,
I have a couple of issues reading OBD data from my car,
and, well, to start at some point, my car is a;
Citroen C3 1,4HDi (diesel)
Year/Month 2003/07
it does have an OBD plug, and the following pins is populated.
Pin - 1,2,4,5,7,11,12,16
so far, it sounds like it is comfortable,
but....
I have tried to use both a Mongoose, and the Elmscan 5 (both USB versions)
software: Scantool, PCMscan and some other.
Neither of the things I have tried seems to be working.
it won't connect at all.
I know that the EOBD is not a requirement before 2004/01,
so the possibility that my car does not have OBD exists.
but, I have had my car at my authorized Citroen Workshop,
and they can connect there equipment to my car,
so some sort of diagnostics is available.
could it be that they pins in the OBD plug is just placed in a NON-OBD std,
and if it is, would it be possible to measure what pins to use..?
or do anyone have any other clues..?
other Citroen owners maybe, who've had the same problems, but found a solution
thanks for all you help
Best Regards
Sean
Sorry for the english
CarPC Specs.
Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
Mcnovy is offline   Reply With Quote
Sponsored Links
Old 09-16-2007, 01:40 PM   #2
My Photos: (0)
Sorry, you car isn't compliant, and will require Citroen specific diagnostics : (
Gareth
UKOBD
UKOBD is offline   Reply With Quote
Old 09-16-2007, 11:18 PM   #3
Mcnovy's Avatar
My Photos: (0)
Thanks for your reply..
Well, I have seen other Citroen C3's from same year (and also Diesel)
being compliant,
so it just sounds weird...
is it possible to get Citroen Specific Diagnostic tools..?
thanks
CarPC Specs.
Old 09-27-2007, 04:04 PM   #4
My Photos: (0)
Did you try?
Hello
Did any of the lights on your ELM light up when you connected?
Look at my post from :08-19-2007, 11:45 PM'
It might be that there is no 12V on pin 16.
Regards!
Carsten
keisen is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
OBD II and Citroen Xsara ThePohorc Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-02-2008 08:41 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
