The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 09-26-2007, 02:15 PM   #1
Jenyus425's CarPC Specs
Jenyus425's Avatar
Vehicle: 2003 VW Jetta
My Photos: (0)
OBD-II for a newbie
This is probably a dumb question but i cannot find the answer on the forums. I have an OBD-II to serial cable. Do i need a scanner to be between the OBDII cable and serial port of the computer? or can i just plug it straight in to the pc?
Jenyus425 is offline   Reply With Quote
Sponsored Links
Old 09-26-2007, 07:49 PM   #2
TonyWare's CarPC Specs
TonyWare's Avatar
Vehicle: 2003 Accord V6 Coupe
My Photos: (22)
First of all there are no dumb questions. Second, yes, plug it in. Third... look for software.
TonyWare is offline   Reply With Quote
Old 09-26-2007, 07:53 PM   #3
Vehicle: 1993 Jeep Wrangler
My Photos: (0)
Is there an ODBII to usb cable around?
underwaterdan is offline   Reply With Quote
Old 09-26-2007, 10:05 PM   #4
joeyoravec's Avatar
Vehicle: 2003 Mustang GT
My Photos: (0)
Vehicles have special networks (CAN, K-Line, J1850, etc.) which aren't the same as serial, usb, ethernet, or anything on standard laptop. At a minimum there will be some electronics to convert the voltage, but usually quite a bit more. They might be in an adapter-box, they might even be hidden in the shell of the connector, but the electronics definitely need to be somewhere.
Companies use 9-pin connectors because they're cheap -- it doesn't necessarily mean that you should plug the cable directly into a serial port. The best idea is to telephone the company that sold you the cable.
joeyoravec is offline   Reply With Quote
Old 09-27-2007, 03:25 AM   #5
My Photos: (0)
Yup I second that! The cable may actually short circuit the serial port on your laptop and cause it to fuxxor up! So don't plug it in, as it most likely does need a scanner! What I think you bought was the cable that goes from car to Elmscan5 scanner.
BiG K is offline   Reply With Quote
Old 09-27-2007, 06:12 AM   #6
TonyWare's Avatar
My Photos: (22)
Oooops, sorry, thought he said he had a scanner with a serial cable.
Old 09-27-2007, 11:56 PM   #7
Jenyus425's Avatar
My Photos: (0)
okay thanks! so, would you guys recommend a certain brand of scanner? one thats cheap, preferably.
Old 09-30-2007, 06:14 AM   #8
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
I think it'd be best to show us what you have first, what brand, from who?
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 09-30-2007, 08:23 AM   #9
My Photos: (0)
There are a number of PC based scantools available, one that we make can be seen at www.obdpros.com. Supports all protocols found on vehicles after 1996. 100% compatible with the tons of OBD II software out there for the ELM chip sets.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 09-30-2007, 03:33 PM   #10
Jenyus425's Avatar
My Photos: (0)
not sure. i got it on ebay for like $8.00
Sponsored Links
Old 09-30-2007, 03:34 PM   #11
Jenyus425's Avatar
My Photos: (0)
Paul
www.obdpros.com
thanks! ill check them out for sure!
Sponsored Links
vB code is On
Trackbacks are Off
OBD II and Citroen Xsara ThePohorc Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-02-2008 08:41 AM
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
does this connector means i have obd II ? (Buick 95') tomer Engine Management, OBD-II, Engine Diagnostics, etc. 8 09-03-2007 07:03 AM
Need help to figure out OBD ii connections virengoyal Engine Management, OBD-II, Engine Diagnostics, etc. 5 12-03-2006 12:14 PM
Newbie question about ODB I and II Nokia6600 Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-24-2004 10:59 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
