The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 09-28-2007, 06:55 AM   #1
My Photos: (1)
ODB-II for the infill G4 and Hummer H3
After installing the G4 and CF1.2, it's time for me to get the ODB-II setup up and running.
Can anyone please tell me what should i purchase for the Infill G4 in order to connect to the Hummer h3 ODB-II connection.
Also - where is the H3 ODB-II connection located?
Thanks in advance for the help
Haim
haiminger is offline   Reply With Quote
Sponsored Links
Old 09-28-2007, 07:26 AM   #2
My Photos: (0)
The OBD II on the H3 should be right under the steering wheel column. The OBD Pro www.obdpros.com supports the H3 protocols, but if by CF you mean centrafuse I think you might have some problems since the H3 has multiple CAN ecu's that respond to OBD II messages and the last version of CF I tried (about 4 months ago) had some issues with handling these multiple responses.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 09-28-2007, 08:16 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
ElmScan tool from the mp3car.com store works as well:
http://store.mp3car.com/ElmScan_5_US..._p/com-039.htm
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-28-2007, 10:13 AM   #4
My Photos: (1)
One more question
Is there a special cable I need to buy in order to connect the ODB component (the one solde here at mp3 store) into the ODB plug I see now under my sterring weel ?
As I see the ODB component sold here has a 9-pin, while the connector in my car is very diffrent.
Old 09-28-2007, 02:08 PM   #5
My Photos: (0)
I think the 9-pin you're referring to is the DB-9 connector that connects to the ELM device. The other end of that cable has a J1962 (16-pin) trapezoid-shaped connector which is what plugs into your vehicle. I that such a cable comes with the ELM device.
Carlocutor is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Infill G4 in Hummer H3 - finaly done, But... haiminger Car Audio 11 02-10-2008 06:06 AM
Infill G4 + Hummer H3 - Finaly DONE !!! haiminger Show off your project 1 08-23-2007 08:16 AM
Hummer h3 - connectios question haiminger Car Audio 7 08-18-2007 08:18 AM
Hummer H3 radio wire diagram haiminger Car Audio 2 08-11-2007 08:44 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
