The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 10-01-2007, 06:34 AM   #1
Vehicle: 2003 Ford BA Falcon XR8
My Photos: (0)
Non OBD ISO9141 usage (and advice on buying standard)
Hi there.
This is a rather techo gory question, but I'm not sure where else to post.
My car has both CAN and Single-Wire ISO9141 busi. The 'OBD' Modules are on CAN (PCM, TCM). Most other primary modules are also on CAN (Cluster, Body Module, HVAC Module, Entertainment Module, ABS for Down-the-Road etc).
But I have a few modules on ISO - ABS for Diag, Restraints Control Module (Airbags) and Park Aid Module (Reverse Sensors).
Would the standard ISO 5-Baud init wake up my bus if the 'OBD' Modules aren't there? Or do I need the ability to change the Init target to be the TA of one of these modules in order to get them to talk to me?
I have an ELM1.1 and Mongoose. I haven't tried the Mongoose with the Drewtech software yet. But I know the ELM1.1 can't do it as that's a feature added in the 1.2 version, along with performance improvements. I'll definitely try #1 shortly, and #2 am querying to see if I can just swap in ELM1.2 in my OBD2AllInOne. But I thought I should try to discuss my thoughts about ISO with someone first.
While I'm here, which 9141 standard should I buy? I'd be mostly interested in the Data-Link Layer up including UDS. (1) The original 9141, or (2) the CARB version 9141-2? (is the 9141-2 amendment adviseable?)
9141-2 is often listed as a 'subset' of 9141 - so it's not clear if one actually supersedes the other or if they are complimentary.
As a private hobbyist I like to know exactly what's in these things before spending my own money.
Lukeyson
Lukeyson is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
