The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 10-07-2007, 03:36 PM   #1
Vehicle: 1993 Jeep Wrangler
My Photos: (0)
Getting rid of my gauges
I can't seem to find an answer for this, so I am going to post it here. Is there a way in my 93 wrangler to have my gauges(gas/4wd/volt/oil, etc) all show up on my carputer so I can get rid of the gauges... Here is a pic of the gauges I am trying to replace.
Project Page - 1993 Wrangler Jeeputer
Progress Meter {**-------} 15% most of the parts are in or have been ordered... Assembly has begun!!!!
underwaterdan is offline   Reply With Quote
Sponsored Links
Old 10-07-2007, 05:17 PM   #2
My Photos: (0)
Not a good idea mate. Imagine this, windows crashes......wtf are you gonna do? lol It is windows, it DOES crash and quite often too!
BiG K is offline   Reply With Quote
Old 10-07-2007, 06:12 PM   #3
GoHybrid's CarPC Specs
GoHybrid's Avatar
Vehicle: 2007 Honda Civic Si Sedan
My Photos: (42)
what is going to go where the gauges were?
GoHybrid is offline   Reply With Quote
Old 10-07-2007, 06:59 PM   #4
My Photos: (0)
If windows crashes I Just reboot :-) truth is I would probably want to keep both for a while...
Old 10-07-2007, 09:59 PM   #5
mrbean_phillip's CarPC Specs
Vehicle: Ford F6 Tornado UTE
My Photos: (0)
This is a myth. If you have properly setup hardware, and take care when setting up the system, and which patches you apply, Windows (as is linux) is rock-solid. I had to go ape**** with worldwide benchmark record-chasing to crash my systems, and those crashes were induced by clocking the daylights out of my system.
I find windows to be utterly stable and reliable - nope, I am not a windows zealot, I use Mac OS X, and Linux too....
To come back to the original question: It would be best if you can use something akin to the new Via Pico atx, or Commell LS-372 3.5" systems, and use Windows CE platform builder to rolout out an OS, which will be very quick on startup, you will be limited with obd-II applications on CE though.
You could use Win XP Embedded, the route I am taking, and strip out everything except what is necessary to display OBD-II data......
Enjoy.
mrbean_phillip is offline   Reply With Quote
Old 10-07-2007, 10:33 PM   #6
FC3S's Avatar
My Photos: (0)
i rarely have windows crash on me. usually i just run too many things and it slows down and freezes..
which like said above if your smart, and dont have that many things running off of the gauge-puter (as it were) then you'd probably be fine
the only problem is what IF something goes wrong :T, mind you your car won't shut down or anything, but yeah, it wouldn't be fun
FC3S is offline   Reply With Quote
Old 10-07-2007, 10:57 PM   #7
My Photos: (0)
Guys, we use Embedded XP nodes to control very expensive processes in industrial control systems, it is widely used, and if properly configured, it should not crash.
Of course anything can and will go wrong at some point in time - but, what will you do if your ecu crash/kills itself.....same thing, you will have a problem.
Properly designed, and configured systems such as these are very reliable.
Old 10-08-2007, 07:41 PM   #8
NiSlo's CarPC Specs
NiSlo's Avatar
Vehicle: 06 Impreza Hatch
My Photos: (16)
As it's a '93 model, I doubt OBD will be an option.
YOu might like to look into the Fusion Brain which was developed by guys here on this forum.
At the moment your gauge cluster is reading the voltages/pulses from the various componenets in your car (speed/RPM etc) and displaying them via yo=ur gauges. The Fusion Brain simply reads these electrical signals and converts them them into a signal yorur computer can understand which you can then use for your virtual displays. . It's super nifty and really cheap and looks like it would do the trick for your setup.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 10-09-2007, 06:30 AM   #9
My Photos: (0)
Now that is exactly what I was looking for - I have a bit more research to do, but that might do it for me!!!!!!!!!!!!!
Sponsored Links
vB code is On
Trackbacks are Off
G Series Vans Look here. DASH GAUGES (BACKLIT) ChevyG20SS General Hardware Discussion 3 09-12-2007 02:12 AM
85 nissan want computer to read gauges Bigrick31 General MP3Car Discussion 7 07-11-2006 03:14 PM
Got rid of BUZZ noise!! bleunetizen General Hardware Discussion 3 10-30-2005 07:20 PM
Best software for displaying gauges? jrtf83 Engine Management, OBD-II, Engine Diagnostics, etc. 1 09-18-2005 06:49 PM
DIY Glow gauges LaserLine Newbie 27 05-08-2004 09:29 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
