The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 10-12-2007, 06:53 PM   #1
Vehicle: Mitsubishi
My Photos: (0)
VAG type diagnostic cables
Question is why will they only work on VAG cars. Is it a peculiar data rate or what have you. I'm dead curious.
Regards
Hawkliney
hawkliney is offline   Reply With Quote
Sponsored Links
Old 06-15-2008, 05:08 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
They don't just work on VW's. I've used mine on both a Honda and a Toyota.
However, only the VAG-COM software will work with the cable. It has all of the manufacturer's codes built in, so you get way more information than the standard OBDII codes. The cable has a chip inside that the software has to read before it will function.
On the Honda and Toyota, you only get the basics. For example, I had a problem with my VW and plugged the VAG-COM cable in. It read back the error and told me it was a coolant temp sensor that went bad. $20 from VW and I replaced it myself. That cable paid for itself already!
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 06-16-2008, 07:18 AM   #3
My Photos: (0)
opal tech2 also works with VAG software the interface is cheap on ebay and I used it on an Audi A3 and VW without any problems but to get the full use of the software there is a license fee to activate it
techbod is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
25 wire data cables peecee General MP3Car Discussion 0 04-03-2006 08:59 AM
Included cables for 700IDT: Length? Viscouse LCD/Display 1 11-03-2005 04:30 PM
Extended VGA and USB cables hylyx LCD/Display 3 08-16-2005 01:31 PM
Longer IDE cables... gizak General Hardware Discussion 1 04-05-2005 11:23 AM
Problem with connecting 2 Type II pcmcia cards to a Type III slot. AVmobile General Hardware Discussion 0 01-28-2004 09:14 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
