The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-04-2007, 02:28 PM   #1
My Photos: (0)
Elm327 Serial to Laptop USB
Hey, my first post!
Just bought (not arrived yet) a Elm327 OBD-II, serial version. Laptop is usb only. Is a simple serial to usb adapter all I need? (could it really be that simple?)
The free software I've DLed is serial only so guess I'll need one that also recognizes usb ports.
Any Recommendations?
MrFrost is offline   Reply With Quote
Sponsored Links
Old 11-04-2007, 10:02 PM   #2
My Photos: (0)
Quote: Originally Posted by MrFrost View Post
Hey, my first post!
You can buy serial to usb adaptors that show the usb as a serial port. Unsure if it will work in your case, but there's a pretty good chance it will. Look on eBay, they're cheap.
fishpost19 is offline   Reply With Quote
Old 11-04-2007, 10:26 PM   #3
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
hardware solution
Hey, my first post!
As you say, a simple USB to serial adapter will get the signal into your PC. It will come with its own drivers that make the PC recognize the serial device as a standard com port. No other software will be needed.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 11-05-2007, 07:40 PM   #4
My Photos: (0)
Thank you both, very much!
Old 11-10-2007, 05:59 PM   #5
My Photos: (0)
Downloaded and installed Huge Pine USB to UART driver and plugged in my 2 dollar adapter.
It's all 5 by 5!
Thanks Again.
Old 12-07-2007, 11:33 AM   #6
My Photos: (0)
Driver Needed
can anyone please send me the driver for the Huge pine usb to serial comm port driver for windows vista 64 bit
hussox is offline   Reply With Quote
Old 12-13-2007, 10:03 AM   #7
Vehicle: 1966
My Photos: (0)
Windows Vista 64
Your the first person that is using windows vista 64 bit for scanning car computers.
Good Luck!
intravino is offline   Reply With Quote
Old 02-24-2008, 11:49 AM   #8
My Photos: (0)
ELM 327 usb serial
Why didn't you buy an ELM327 USB version. You can get both serial and USB versions.
All you do then is use the default WinXP or Vista driver and it works fine.
Had a USB version for a week now and seems fine.
I keep trying to find cars with different protocols just to test it out.
Cyborg is offline   Reply With Quote
Old 03-08-2008, 02:18 AM   #9
My Photos: (0)
Cyborg,
Since you have a working system. I just want to get the same one you have to avoid compatibility issues. Can you tell me what s/w you use with the ELM327 USB.
camy990 is offline   Reply With Quote
Old 03-08-2008, 05:16 AM   #10
My Photos: (0)
Camy990,
I've been using Vista Home Premium on a laptop. I've used ProScan 5.1 and ScanTool.net.
Both work well. Versions of VAG-COM above 409.1 need a dongled interface and I couldnt as yet get it to work. There are alot of other free tools out there if you look. Vista installed its default drivers for the USB ELM and worked first time. I've installed it on an XP Pro desktop aswell and that used its default drivers. If you test your setup it wont find the interface untill you plug it into a car and turn the ignition or start it, also make sure the caris OBD compliant. After 2004 diesel after 1996 petrol I think.
If theres any other questions get back to me.
Sponsored Links
Old 03-08-2008, 10:19 AM   #11
My Photos: (0)
Appreciate for your help Cyborg. The ElmScan 5 USB ScanXL model at scantool.net should have more than what I need.
I'm using a laptop with xp home OS and PIII processor, hope it works. Will find out soon.
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 80 07-16-2008 12:42 PM
usb serial adapter snotty87 General Hardware Discussion 1 08-26-2007 11:45 PM
How can I use a laptop as a carpc? turbocad6 Laptops, Tablets, UPMCs, etc. 0 07-11-2007 12:55 AM
OnDigital IR reciever serial connector convert to USB or Parralel? ruairi Input Devices 3 03-09-2005 12:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
