The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 12-20-2007, 12:42 AM   #46
Vehicle: Ford Territory Ghia Turbo
My Photos: (0)
Quote: Originally Posted by customaudioman View Post
What hardware do I need for this to work with my carputer setup? Can I use any cable? I download your software. Also can it work within streetdeck frontend or out side the program only?
You nned a OBD11 interface, such as the ELM as well as cables. If you take a look at
http://www.palmerperformance.com/sto...products_id=32 you would see exactly what you require. If you downloaded the SCANTOOL software, you would be best to get their "package" which incorporates the license as well as the cables and interface dongle.
allypally is offline   Reply With Quote
Sponsored Links
Old 12-21-2007, 11:39 AM   #47
PPE
PPE's Avatar
My Photos: (0)
Quote: Originally Posted by C4DAO View Post
@ PPE
Sorry mate to bug you but you may have missed my question above:
"Excuse me for not doing my research, but will your hardware work with CANBUS? Specifically a Citroen C4 2005 model. I would be very interested if it did..."
To add to that..any chance you could post that Nissan skin so I can download your software and try it out?
EDIT..didn't look properly..I see your download link now!
Sorry about that. The answer is yes - our hardware interface (ELM327 based) does support the CAN protocol. It will work on any OBD-II/EOBD compliant vehicle.
PCMSCAN - Check it out at: http://www.palmerperformance.com
PPE is offline   Reply With Quote
Old 12-21-2007, 11:42 AM   #48
PPE
PPE's Avatar
My Photos: (0)
Quote: Originally Posted by _Dejan_ View Post
I will say in this way. This software doesen't work right with my car. You can see on photos that doesn't show right values and Im shure that my car on idle don't run with 200-240rpm. So Im looking for software where I can "calibrate" this values...
P.S. by hyperterminal I ger values of real rpm so I get 800-900
What kind of vehicle do you have? Are you sure it's fully OBD-II/EOBD compliant? Based on your posts, it sounds like it isn't fully compliant.
However, our PCMSCAN software has a powerful feature that will be able to fix this. Just create a custom Javascript parameter (go to the Tools menu -> Script Editor) that takes the value of SAE.RPM and multiplies it by 4. Then you should be seeing the proper RPM. Of course, you'll have to edit the dashboard layouts to use your new script RPM parameter.
Old 12-21-2007, 11:46 AM   #49
PPE
PPE's Avatar
My Photos: (0)
If you are asking about our PCMSCAN software, then see Dejan's post right after yours. He has listed all the hardware interfaces that PCMSCAN is compatible with.
For our DashCommand software, it currently only supports ELM interfaces.
I'm not too familiar with how to embed software into StreetDeck, but I would imagine that it should be possible to get both PCMSCAN and DashCommand embedded within it. However, DashCommand supports a few command line parameters that makes this process a little easier.
Old 12-23-2007, 05:54 AM   #50
_Dejan_'s CarPC Specs
Vehicle: 2004/Fiat/Stilo 1.9 JTD 160HP
My Photos: (0)
I have Fiat Stilo 1.9JTD (year 2004) and I don't know if is fully EOBD compatible, I will try do something with script editor when I will have some time...
_Dejan_ is offline   Reply With Quote
Sponsored Links
Old 12-25-2007, 01:41 AM   #51
Vehicle: 2006/MAZDA/MAZDA 3
My Photos: (0)
Hi PPE ;
I am new here from Jakarta Indonesia and just buy PCMSCAN with ELMSCAN 5 from Singapore and I will recived at 27 Des 07 so if I need help can I email to U also how to registered the software?
I want to used wiyh my MAZDA 3 HB 1.6 L A/T Black Metalik also new from Dealer Here in Jakarta-Indonesia.
Billion is offline   Reply With Quote
Old 12-28-2007, 08:18 PM   #52
My Photos: (0)
Thank's to PPE and Singapore Distributor.......
I just recived The License Software PCMSAN, and before I already use the demo version. From I get the license so is more thing I can do with the PCMSCAN.
Old 01-03-2008, 04:32 AM   #53
ShawJohn's CarPC Specs
ShawJohn's Avatar
Vehicle: 1999 Nissan 200sx S14a (280bhp)
My Photos: (0)
Quote: Originally Posted by copter View Post
I too need these for turbo boost, exhaust gas temp and rear diff temp.
Unless you add pressure sensors and extra temp sensors you've got no chance.
The Nissan systems don't measure boost at all! They measure airflow and air temp.
Hence why its called a Mass Air Flow system.
EGT also needs extra electronics and AFAIK isn't going to happen with Nissan Consult hardware... It would be easier fitting a new ECU like a GEMS setup to do what you want
There's also ECUTalk for gauges
ShawJohn is offline   Reply With Quote
Old 01-05-2008, 09:02 PM   #54
Tissy's CarPC Specs
Tissy's Avatar
Vehicle: Subaru Impreza 2005
My Photos: (0)
Just ordered DashCommand and its is now on special offer
With the MP3Car discount, it only works out at $21.21. Looking forward to integrating it into RoadRunner now
Lets see if we can get some more great skins designed !
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
Tissy is offline   Reply With Quote
Old 01-06-2008, 12:43 AM   #55
copter's CarPC Specs
copter's Avatar
Vehicle: 2K6 DURAMAX
My Photos: (0)
If I get the probes from known guage makers is there any way to connect to the PC?
_____________________________
06 BLACKTIE LBZ | GRAYSTONE METALLIC | MBRP 4" | AMP STEPS | KMC DIESELS | TOYO M/T'S | NCT/COGNITO 4-6" | BILSTEIN 5100'S | MAG-HYTEC DIFF COVER | HID'S | PPE XCELLERTOR |
______________________________________
copter is online now   Reply With Quote
Old 01-07-2008, 09:03 AM   #56
ShawJohn's Avatar
My Photos: (0)
Its not been done yet to AFAIK.
Not unless you're good at programming and have a knowledge of electronics.
I suppose it could be done using one of those USB relay board thingies
Old 01-07-2008, 03:58 PM   #57
Tissy's CarPC Specs
Tissy's Avatar
My Photos: (0)
Looks like i have succedded in embedding DashCommand into RoadRunner.
Looks pretty good IMO.
Old 01-07-2008, 10:27 PM   #58
morris_the_cat's Avatar
Vehicle: 2001 PT Cruiser
My Photos: (0)
Wow Tissy, that looks great! Care to post the skin files & give a howto?!!?? I think I may have to buy this software now!
2001 PT Cuiser
VoomPC with 1.5Ghz C7
M2 power supply
in dash slim tray dvd drive
DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
See my install here
morris_the_cat is offline   Reply With Quote
Old 01-08-2008, 02:22 AM   #59
Tissy's CarPC Specs
Tissy's Avatar
My Photos: (0)
The base Skin is called Simplistique, however, it has since it was developed some considerable time again, been heavily moddified and built on by me.
For those who know how to skin edit, you will need the following.
Create a skin page with a predefined "Application" area.
Here is an example of such, call it obd.skin
MEDIACAR Skin
MEDIACAR MM Skin
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B21,1,523,110,79,"CLOSE","Exit"
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L01,283,31,74,35,255,102,0,18,"Digital Readout Thick Upright:B","REMAININGTRACKTIME",""
L02,6,31,268,35,255,102,0,18,"Digital Readout Thick Upright:B","/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
/, A, x, y, w, h, color R;RGB, G, B
A01,0,81,800,440,000,000,000
/, I, x, y, w, h, Code;INDICATORCODES
/, Y, Back Slider file path
Y01,"\volume_slider\volume_*.jpg"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
END
This will give you a basic skin with a close button and also track names etc.
Then, add a button to your main 'menu.skin' and have the 'command' field labelled as:
"LOAD;obd.skin;DashCommand;C:\Program Files\DashCommand\dashcommand.exe;!wxWindowClassNR "
Obvioulsy, the 'C:\Program Files\DashCommand\dashcommand.exe' needs to be where the where YOUR DashCommand exe is stored.
I haven't tried it in the car yet, but see no reason why it won't work.
Old 01-11-2008, 12:39 PM   #60
krnpimpsta's CarPC Specs
krnpimpsta's Avatar
Vehicle: 2008 Ford Mustang GT
My Photos: (0)
How long did it take for you to create the guts of that? As in, not the graphical skin itself, but the stuff controlling how those gauges act in response to OBD-ii inputs? I already have a $600 Ford usb/obd-ii scanner/programmer, but am on the fence for a compact read-only unit with this dash command software, but I don't have much time to invest into learning/coding/skinning..
krnpimpsta is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
SDPIF digital Coax into car audio pieces Red GTi VR6 Car Audio 13 08-15-2005 12:47 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
