The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-12-2007, 10:28 AM   #1
My Photos: (0)
Unsupported O2 Sensor - IS it car or Scanner
Hi, I just bought an ELM 327 and connected it to my 2003 Toyota Camry LE.
I needed to look at the O2 sensor reading, but I can only see the Bank 1 Sensor 2 reading. All the software I've downloaded (Scantool.net 1.1.3) and others say that Bank 1 Sensor 1 is not supported. I thought all cars that were OBD2 supported this? Is it something in my Camry? The Scanner Software? The ELM 327 chip?
I doubt this car doesn't have an Upstream O2 sensor, as I believe it comes from California.
danalmsa is offline   Reply With Quote
Sponsored Links
Old 11-12-2007, 10:36 AM   #2
joeyoravec's Avatar
Vehicle: 2003 Mustang GT
My Photos: (0)
I agree, it's a little hard to believe that there's no bank 1 sensor 1. You might want to try different software. I know PCMScan has a fast mode that trusts the cars "supported signals" list, and an aggressive mode that doubts the car and tests each signal individually. The aggressive mode takes longer, but sometimes it works better.
It's not the chip -- if you can get one signal, you can get them all. Post the results if you try some other software. I'm curious to hear if it's the software or just the car.
joeyoravec is online now   Reply With Quote
Old 11-12-2007, 12:28 PM   #3
My Photos: (0)
Ok. I tried, but, without paying for the software, I can't test it.
I connected the scanner to the Car again and the return data for PID 13 indicates only B1S2 is supported. On another note, I read somewhere that some Toyotas use an Air Fuel Sensor and not a O2. I thought they were the same, but I'm probably mistaken. If that were the case, does anyone know if a Toyota Camry has extended PID codes, and what they are?
On a side note, the readings for the S1B2 indicates a voltage of .72 most of the time. Sometimes it cycles, but not always. Shouldn't the sensor after the CAT be closer to .45?
Old 11-12-2007, 12:37 PM   #4
joeyoravec's Avatar
My Photos: (0)
I've heard people use the word air/fuel sensor also. Maybe some of the imports use that word in their shop manuals? Another wild guess -- maybe your car uses a wideband sensor in that position, so check pids $24 and $34. You were using $13 to $1B which is only for conventional narrow range sensors.
Old 11-12-2007, 01:27 PM   #5
My Photos: (0)
Though I haven't checked, I believe your guess is not so Wild. I've been looking on the web and it looks like that Air/Fuel Sensor is a Wide Band Sensor. I found a web site that talked about Toyota Solara and it indicated the A/F voltage is from 0 to 4 and can be read through the same PIDs you mentioned.
That makes me believe PCMScan will read it because that PID is in the list of items it can record.
Sponsored Links
vB code is On
Trackbacks are Off
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 07:34 AM
In a real PC car struggle markland556 Off Topic 10 06-27-2007 11:36 AM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 10:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
