The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 11-25-2007, 12:51 AM   #1
My Photos: (0)
07 GM question, possible PCM programming?
Hey, I am not sure where to ask this but maybe you guys can help me.
I have a 2007 Suburban that needs some "work" done. There are a few things I really dislike about the car and I am wondering if its possible to fix.
First off I hate the damn door/key dinger. Normally you can pull the relay deal out to disable it, but this car it runs through the radio so I can't disable it.
Second, I am limited to having 3 keys that can start the car. I need more.
I looked into some software/hardware to program the PCM to do different things. Obviously its all engine related and I didn't see anything about little things like I would like to have done.
Does anyone have any info or a good place to start on how to fix this?
Any help would be great, TIA!
Edit:
Oh, also I hate the seatbelt dinger. Annoying as all hell. Thats another thing I would like to disable. There are a few more things too similar to the above, but I can't think of them off the top of my head.
equate975 is offline   Reply With Quote
Sponsored Links
Old 12-24-2007, 09:35 PM   #2
My Photos: (0)
The easy fix is to just pull the relay. You can buy Flashscan V2 if you're willing to make the investment. It's more performance oriented, but it can do things to modify BCM controls.
eallanboggs is offline   Reply With Quote
Old 12-26-2007, 07:56 AM   #3
My Photos: (0)
The Dinger is know as the Chime. The Chime is responsible for all of the annoying dings in your car such as the open the door with key in ding, and the turn signal click clack... etc. To disable it you have to use a factory scan tool to set the volume level of the chime to something you can't hear. So you might be able to talk your dealership into helping you out with the tool.
FYI Chime is made audible by messages send from the BCM to the Radio head unit. So you could just get rid of your radio..
chewwtoy is offline   Reply With Quote
Old 12-26-2007, 09:31 PM   #4
redls1bird's CarPC Specs
redls1bird's Avatar
My Photos: (0)
Good luck getting you dealer to disable a safety feature. If they do, theyre pretty brave considering the shi* storm the manufacturer could bring down on them for doing so. The number of keys is likely a limitation set by the bcm or ecm (whatever module holds the "immobilizer" codes in it). From all my experience, this will not be able to be changed if they used a substatial theft deterent setup. In reality, i can understand the keys, but why defeat the seatbelt chime? Its their to help you stay safe by having your belt on and your doors closed while the vehicle could start moving.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 12-26-2007, 10:40 PM   #5
My Photos: (0)
Check your owners manual. My 2007 Suburban can have up to 8 keys and 8 Keyless remotes programmed at any one time.
I can also change the chime volume but I don't think you can turn it off.
KCarPC75 is offline   Reply With Quote
Old 01-05-2008, 01:00 PM   #6
moboman's CarPC Specs
moboman's Avatar
Vehicle: 1997 Chev Astro Cargo
My Photos: (0)
If you replace the head unit in an 07 Gm, the chime is an optional 100 piece of equipment. The one we used has a lot nicer of a chime than the factory and it is quieter. Here is a picture of the avic-z2 in an 07 express.
My Worklog
I'm using my carputer 100%, but I still need to make it easier to use.
moboman is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Programming question dfk70 Software & Software Development 6 11-23-2005 12:41 PM
PCI or PCM? that is the question aBs0lut30 Wireless Communications 1 12-17-2004 04:59 PM
Programming Question in VB az1324 Software & Software Development 8 10-01-2004 09:24 PM
This may be more of a programming question.. but here goes bklynkaos General Hardware Discussion 1 02-09-2004 10:11 PM
Out of topic programming question (VB) darkwingduck Software & Software Development 5 09-01-2000 06:55 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
