The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 08-01-2001, 03:45 PM   #1
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (226)
Quote: Originally Posted by Bibo60 View Post
Thank you very much , it is same like yours, Just instruct me how to download it. Thank you again,
Bush
Check your email........... sent you the file.
HiJackZX1 is online now   Reply With Quote
Sponsored Links
Old 12-18-2007, 03:12 PM   #2
HiJackZX1's Avatar
My Photos: (226)
Bought a ELM 327 and it doesnt work!!!
I bought a ELM 327 scanner and it does not connect to my truck currectly (PC wise). I can not get any information out of it. So I am calling for help. I know there is a guy on here that has a Jeep with a 4.7L V8. I think it is the exact same engine in my truck which is a Dodge Durango w/ a Magnum 4.7L V8. I cant even seem to find what type of system the truck uses on the internet. I do know that when I plug into the OBD2 port the power light comes on, but thats about it. I bought the scanner awhile back so I probably cant return it, so I would like to see if I can get it to work. It is similar to this one http://cgi.ebay.com/ebaymotors/ws/eB...m=160177737351. Some one please help :-(
Old 12-18-2007, 04:41 PM   #3
NiSlo's CarPC Specs
NiSlo's Avatar
Vehicle: 06 Impreza Hatch
My Photos: (16)
According to that ebay page, it supports all protocols so it shouldn;t matter what vehicle you connect to (as long as it's OBD compliant). It seems as though it has a fixed baud rate of 38400. What software are you using. Do you have the baud set to 38400 in the software settings?
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 12-18-2007, 05:59 PM   #4
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Have you set the proper COM port in the software?
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 12-18-2007, 06:09 PM   #5
HiJackZX1's Avatar
My Photos: (226)
Someone told me that my car uses SAE which is listed.... Honestly I do remember playing with the baud rate, but not sure if I tried 38400. The software I am using is Centrafuse. I guess I have alot of gear on my PC so when I installed the OBD2 scanner, it was set at port 17. The software that came with it, only goes up to port 5, Centrafuse goes up to 17, but it will connect then say error. I hope its as simple as it being the wrong baud rate.
Old 12-18-2007, 06:10 PM   #6
HiJackZX1's Avatar
My Photos: (226)
I think I have, it installed on port 17, and I set the software (Centrafuse) to 17. The original software only went up to 5.
Old 12-18-2007, 06:14 PM   #7
_
My Photos: (73)
Have you tried it outside of Centrafuse with the provided software?
Jan Bennett
Old 12-18-2007, 06:36 PM   #8
NiSlo's CarPC Specs
NiSlo's Avatar
My Photos: (16)
Do the following for me. Goto Control Panel > System > Hardware > Device Manager > Ports and find the exact port that you are using. If you're not sure which one it is, disconnect the OBD-II reader from the usb port and then plug it back in to see which one dis-appears then re-appers. The comport will be listed in brackets next to the name of the device.
Now that you have determined exactly which port you are using, jump into Centrafuse, set the port number, set the baud rate to 38400, set the device to the elm327 and see how you go.
You should the lights on your OBD-II interface 'dance' around as it connects. It does take a few seconds to do so.
Old 12-18-2007, 10:25 PM   #9
My Photos: (0)
The Dodge is most likely ISO9141 or VPW but the link you provided does say that it supports those protocols, I would try what NiSlo recommended and also try connectibg using hyperterminal just to eliminate additional variables initially
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 12-19-2007, 07:57 AM   #10
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
I bought the same one, and it's being installed over the next week (along with everything else).
I'll hopefully be able to update you on if mine works, and specific settings I used.
Phatsacks is offline   Reply With Quote
Sponsored Links
Old 12-19-2007, 10:19 AM   #11
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Paul
www.obdpros.com
VPW IIRC...............
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 12-22-2007, 07:47 PM   #12
AllThingsEnd's Avatar
Vehicle: 02 Durango
My Photos: (0)
hey hijack, did you ever get this to work? ive been wanting to buy a OBDII interface for my truck.
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:
SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
AllThingsEnd is offline   Reply With Quote
Old 12-23-2007, 07:06 PM   #13
HiJackZX1's Avatar
My Photos: (226)
Not yet, right now my car PC is in pieces (upgrading the power supply) and since the OPUS 320 is so large, I have to customize the case to install it. Tomorrow I will be putting it back together and the first thing Im doing is trying the scanner again.
Old 01-03-2008, 10:34 PM   #14
My Photos: (0)
Hello Guys,
I bought ELM 327 unit . I received the cd damaged. I can not install it without the driver. can any one tell me how to solve this issue. Please if any one has the driver cd to e mail me the drivers at b_al_dhany@hotmail.com.
Thank you
Bibo60 is offline   Reply With Quote
Old 01-04-2008, 06:17 PM   #15
HiJackZX1's Avatar
My Photos: (226)
Hello Guys,
Thank you
which unit did you buy though? the same as mine? did it come from hong kong? if yes I can let you down load it from my FTP site.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
