The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 12-22-2007, 10:34 AM   #1
My Photos: (0)
Reading Resistance OBD 1
Ok I got a 1990 Mazda 929. I want to monitor most of the engine sensors from a computer. All of the sensors operate by sending resistance to the ECU. I have the splice harness from Mazda's engine signal monitor. I need something that can read most of the 67 sensors in this car. Anything out there that can do it?
jsingh90210 is offline   Reply With Quote
Sponsored Links
Old 12-22-2007, 10:46 AM   #2
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
You want to read the sensors directly? not via serial? If that's what you're saying, a few fusion brains may be able to handle that job.
h3rk is offline   Reply With Quote
Old 12-25-2007, 03:31 PM   #3
My Photos: (0)
can it be read through serial??? I have a splice harness and the technical specificaitons for each sensor. instead of connecting a multimeter, reading the resistance of a sensor and then going through the formula just to find out whats the coolant temp. I'd like to just have it at my fingertips . and see whats what so I don't blow my car up.
Sponsored Links
vB code is On
Trackbacks are Off
OBD II connector on an OBD I car HearseNurse Engine Management, OBD-II, Engine Diagnostics, etc. 3 01-20-2008 11:24 PM
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
OBD and Citroen from 2003 (Diesel) Mcnovy Engine Management, OBD-II, Engine Diagnostics, etc. 3 09-27-2007 04:04 PM
OBD or special hardware? Jirka Jirout General Hardware Discussion 2 03-04-2007 05:01 AM
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 03:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
