The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 01-03-2008, 04:45 PM   #1
My Photos: (0)
OBDII e46 Socket Location
Just to verify... are these the ONLY two locations for OBDII ?
Engine Compartment (Round)
Under Steering Wheel area (Rectangle)
If so, is there a round to rectangle converter -- I ask because I just got my OBDII scanner for use with Centrafuse, but where it's located will be in the way quite a bit -- was hoping for constant connectivity.
(reference pix for obdii connection in '02 e46 325Ci -- Interior, Rectangle):
house98 is offline   Reply With Quote
Sponsored Links
Old 01-03-2008, 10:16 PM   #2
My Photos: (0)
The one you are seeing should be the OBD II connector, typically I have only seen one connector per vehicle so I think the round one that you are seeing is most likely not an OBD II port, does this one have 16 pins??
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 01-04-2008, 08:33 AM   #3
My Photos: (0)
Thanks Paul.
I'll check later tonight. There's supposedly one in the engine area for BMW diagnostics (from what I've read) -- but it just seems like there would be another more tucked-away version that I could drive around with and not worry about kicking out of socket.
Maybe if they make a slimed-down 'right-angle' version that I could keep closer to the under-belly of that area vs. the 3" mass...
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 80 07-16-2008 12:42 PM
OBDII for ELM323 hjcho616 Road Runner 5 11-29-2007 09:14 AM
Automatic Weather Update/GPS Location Labels.. How they work and problem solving. Sonicxtacy02 RR FAQ 2 10-10-2007 08:24 AM
OBDII Signal Splitter (for Infiniti G35) Caelric Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-14-2007 08:32 PM
Pentium 4 M - General Intel Socket Confusion Questions MackDSM General Hardware Discussion 8 06-15-2006 03:40 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
