Just to verify... are these the ONLY two locations for OBDII ?
Engine Compartment (Round)
Under Steering Wheel area (Rectangle)
If so, is there a round to rectangle converter -- I ask because I just got my OBDII scanner for use with Centrafuse, but where it's located will be in the way quite a bit -- was hoping for constant connectivity.
(reference pix for obdii connection in '02 e46 325Ci -- Interior, Rectangle):
