The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-15-2008, 01:08 AM   #16
Vehicle: 2004 VW Jetta TDI
My Photos: (0)
Oh by the way I'm looking for one from ebay unless I can find a cheaper one somewhere else.
Cybergeek is offline   Reply With Quote
Sponsored Links
Old 04-26-2008, 07:43 PM   #17
glm
My Photos: (0)
Hi cybergeek,
Depends on the Elm327 interface. If you are connecting to a serial port directly then no driver required. However if you use a USB serial adapter to provide a virtual port or you use an Elm327 USB scantool, then a driver is required. In both cases the driver should be supplied with the equipment.
Graham McKechnie
http://www.glmsoftware.com
glm is offline   Reply With Quote
Old 05-03-2008, 07:32 AM   #18
My Photos: (0)
Quote: Originally Posted by stroths View Post
Don't buy that scan tool. It's a knock off and does not use a genuine Elm327 chip.
The biggest red flag is the cost. A genuine Elm327 chip costs around $20 by itself (even when purchased in bulk).
Big_Mike is offline   Reply With Quote
Old 05-03-2008, 08:11 AM   #19
My Photos: (0)
The OBDPro interfaces will work with all ELM compatible programs and now we provide speeds of upto 1.2 Mbits on the USB interfaces.
Paul
michbound is offline   Reply With Quote
Old 05-10-2008, 12:53 PM   #20
My Photos: (0)
obd interface module
I recently purchased the elm327 from an ebay site for $34 w/shipping (but-it-now cost). As far as double buffering??? - don't see any with real-time updates. Interfacing to XP OS is simple and used scantool.net free version for code reading and real-time diagnostics. Read earlier that the ProScan 5.1 software is good, but interested if anyone else some ideas on the best software under $100???
Dave
dbanerian is offline   Reply With Quote
Sponsored Links
Old 05-11-2008, 09:27 PM   #21
My Photos: (0)
Dave
I'm sorry I don't understand did you like your ELM from ebay? See the way I look at it as long as it works it's all good, no need to spend hundreds of dollars and if it does die well its only 40 bucks at least you can say you did what you had to.
Old 05-11-2008, 09:36 PM   #22
My Photos: (0)
i just bought an obdpros scanner and couldn't be happier with it. it works very well.
i noticed the seller is in china, and i think i read somewhere that they have a machine that can scan a chip and reproduce it cheaply, that might be what this is. (just a thought)
in any case, it's worth the extra twenty or thirty dollars to get one from a reputable company. good choice.
jash7 is offline   Reply With Quote
Old 05-11-2008, 10:44 PM   #23
My Photos: (0)
I heard something like that too
Old 05-12-2008, 07:46 AM   #24
My Photos: (0)
hate to spam this around, but in this thread i also was looking for a obd and can interface tool. http://www.mp3car.com/vbulletin/engi...d-can-bus.html
Main problem, my obd connector does not have any CAN-bus, from what i see. But i know my car has both p-bus and i-bus running on the can network, What should i do? shout i tap and re rout a few wires back to the connector. Secondly what is the best all around tool for CAN and OBD for a 99 Saab 9-5? what if i was on a budget what would you recomend?
nblracer is offline   Reply With Quote
Old 05-12-2008, 09:38 AM   #25
My Photos: (0)
nblracer,
rerouting wires might not help as some of the can buses are single wire and will not work with the 2 wire scantools, can you list out what pins are populated on the OBD II connector, if the vehicle is a 99 Saab I suspect it might be using the ISO protocol for OBD II and not the CAN protocol.
Paul
www.obdpros.com
Old 05-12-2008, 09:50 PM   #26
My Photos: (0)
obd scan interface - elm 327
Very happy with the ELM327 v 1.2a performance of the $34 interface. Used it on three different autos any locks right on, and yes I'm pleased. As far as Chinese knock-offs, scanning chips and making dups - thinks that's a stretch. The chip in this device is the ELM chip and even if it's a manufactured part through some other company - so what this is the norm in the semiconductor industry - they simply buy the die designs and fab it themselves. The web site I purchased it from is:
http://motors.search.ebay.com/_W0QQsassZtangxiaorui2000
Dave
Old 06-03-2008, 05:39 AM   #27
My Photos: (2)
I just bought the same device off e-bay. I will test it out in an auto shop and get back to everyone. The shop is using the odbpro module and it works great. So it will be a good comparison between both modules.
I remember coming to the shop with the obdpro module. The tech's laughed their heads off. Not a Hunter or Snap-on hardware device, but it's worked great so far. The module has reset various computer check engine lights that their old snap-on module could not.
It's also working great for the CAN vehicles.
2003 Black Impala
Dwaine is offline   Reply With Quote
Old 06-03-2008, 11:44 AM   #28
My Photos: (0)
I bought this device and it works good I also have Proscan software and I was supprised at the 0-60 times it gives me and all the other info. Overall I'm happpy with it but if there is something I dont know about it let me know please.
Old 06-03-2008, 12:18 PM   #29
My Photos: (0)
Dave
Actually there are a couple of things to point out on the one being sold on ebay...
Though it says ELM 327 v1.2a it is actually the older ELM chip how can you tell? Well connect to the device using hyperterminal and then type in ATI and hit enter - the response back will show the ELM firmware version
This means you will not be able to get the higher speeds possible with the ELM 1.2 or with the OBDPro devices. OBDPro devices now can go all the way upto 1.25 Mbits on the USB versions
It also does not support some of the newer functionality that an OBDPro will support such as adaptive timeout values - what the adaptive timeout value does is monitor how long it takes for the vehicle to respond to a query and adapt appropriately - this allows for faster data from vehicles.
Also for CAN vehicles the device will quickly show a buffer overflow message if one was to try monitoring all messages on the fast can bus via ATMA. The OBDPro devices can keep up with all the CAN traffic on the bus - even on the high speed can buses operating at 500KBPS
Paul
www.obdpros.com
Old 06-03-2008, 01:12 PM   #30
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
Well I bought my ELM327 from obdpros.com...... I had bought a USB unit originally from ebay and it cr@pped out after only a few uses. I decided to buy the serial version, because I have way to many USB devices and am really shy of over loading the USB bandwidth. Since I have 4 serial ports I figured Id use the last one left for the OBD2 scanner from them..... Tommorrow it will be in the mail, I am sure I will be very happy with it!
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
USB Adapter for XM Direct timekiller Linux 1 10-15-2007 11:21 PM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 11:14 AM
OBD II from Walmart...USB works? sgtpepperaut Engine Management, OBD-II, Engine Diagnostics, etc. 5 05-01-2007 12:10 PM
Touchscreen changing usb event device on power on/off pkg Linux 14 08-15-2005 06:27 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
