The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 01-20-2008, 10:09 PM   #1
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
Nissan HVAC LAN --and test equipment for sniffing unknown bus
I think this falls under the "etc." portion of this subforum's title:
I have a project that requires a PC to be able to control the mode, recirc, and blend doors in an automotive HVAC system. This is a pretty straight forward process with an IO board like the fusion brain when the doors are driven by motors with variable analog signals, vacuum actuators, or servos driven by different voltages sent from the controller to open, close, hold the door based off of potentiometer feedback. I have changed the vehicle I'm first building this on, and I have run into a snag. The 3 servos that drive the doors in question are controlled locally. These 3 local control units drive the doors in relation to data sent on a common 1 wire bus.
They respond to addressed packets of data (if the address matches theirs). This bus is local, and not tied to the DTC via CAN or any other "reserved for mfr." position. This HVAC LAN is something I will have to tie into at the connector. I hope to connect in a manner such that I may first monitor, or sniff the message traffic so that I may decipher the protocol enoughto be able to replicate the messages sent from the OEM controller.
So I'm looking for a solution that will allow me to read the bus and subsequently update values in the software. And as the software begins to take a controlling role, the solution should probably provide a means to isolate the OEM controller during periods of computer control.
The voltage level at the bus is indicated to be 5.5Vdc in the service manual.
I'm at a loss for what kind of hardware to use (and accordingly, software - for sniffing). Have you worked with this small network before? Any insights into what steps to take? I've heard a rumor that the way addressing is implemented isn't actually by a block of bits after the start block, but in the frequency of the signal sent. I hope that's not true, because I'd be even more clueless as to how to tackle that.
So to make for some specific questions:
How do you attack a completely unknown data bus, when only a basic outline of the protocol is known?
- How do you determine the data rate? (trial and error?)
- Is hyperterminal the standard tool of choice for initial sniffing?
- I'm thinking it's not going to be as easy as hooking in to the Rx on a serial port, what hardware would I need in-between?
- Would it be more inportant to crack the HVAC controller open, and try to find out what chip is sending this signal directly?
What kind of switches are best suited for substituting the PC in place of the HVAC controller temporarily, on this 1 wire bus?
h3rk is offline   Reply With Quote
Sponsored Links
Old 01-26-2008, 11:57 PM   #2
Vehicle: 2003 Ford BA Falcon XR8
My Photos: (0)
I have a similar task to complete shortly - with a 'Memory Controller' that is connected to Mirrors, Seat and Pedals. The Mirror in particular has a sub-module that is responsible for mirror control but is connected to the Memory Module by a single data line.
The only way I know how to see this is with an oscilloscope, and it sounds like you might be in the same situation my friend. I am suspecting that the Memory Module has to send a 'position number' to the mirror controller - Position 1,2, 3, and Reverse - and the Mirror module is responsible for remembering it's direction for each of the memory 'positions'.
The question for me is, how did you even get that information for the frame format?
Lukeyson
Lukeyson is offline   Reply With Quote
Old 01-27-2008, 01:31 AM   #3
h3rk's CarPC Specs
My Photos: (0)
Lukeyson
Yeah, scope, logic analyzer, the whole deal. I haven't worked with that stuff in like 10 years. It'll be fun.
I got the little data I have to start from straight out of the service manual. I was really impressed when I saw it there. Although I then wanted just a few more bits of information. "Give and inch..."
Old 04-18-2008, 02:20 PM   #4
h3rk's CarPC Specs
My Photos: (0)
USBee DX. What do you think of this product? Have you used it? I know it's expensive, but it seems like a great tool to have. Would it do the job for my situation?
I've been off of this for a little bit, but coming back to it, I decided the first order of business is to look for the right tool for the job. So in my searching, it seems like this will work. I like its advertised versatility.
But hopefully I can get some feedback before I splurge.
Anything better suited, that you know of?
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 80 07-16-2008 12:42 PM
Ford HVAC Controls brandname2007 General Hardware Discussion 5 12-31-2007 02:56 PM
Nissan skin djR1SpecV General MP3Car Discussion 6 01-11-2006 10:25 AM
HVAC controller standards mithoric Software & Software Development 2 09-20-2005 10:09 AM
FS: 802.11b Wireless LAN PCI NICs (2.of). buildfromscratc Classified Archive 2 07-29-2004 04:59 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
