The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 01-22-2008, 07:35 PM   #1
My Photos: (0)
Question help with ecu diagnostics!!!
okay guys before i buy all the car pc parts i just want to make sure i can do this. i have a 1998 mustang 3.8L. i want to install a car pc, but the only reason i would do this is to get real time engine stats. i know i would need a cable from the chip in the car to usb but i was hoping someone can give me some guidance as to how to do this and where to buy the cable before i go buying all the parts for the car pc. thanks!!
jash7 is offline   Reply With Quote
Sponsored Links
Old 01-22-2008, 09:35 PM   #2
My Photos: (0)
Jash7,
what sort of data would you like to capture? If you are looking at the standard OBD II data engine rpm, coolant temp. o2 sensor reading, MAF and so forth our OBDPro interface will work fine.
Both our USB and Serial interfaces come with all the cables needed to start logging data, all you need to provide is the carpc.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 01-22-2008, 09:38 PM   #3
My Photos: (0)
cool thanks, can i use this stuff to tune my chip for fuel economy, performance, etc.?
Old 01-22-2008, 10:11 PM   #4
My Photos: (0)
oh and do i have to use your software or can i use anyones software? what is the diforence between the product link you gave me and other ones?
Old 01-23-2008, 07:27 AM   #5
My Photos: (0)
No the OBDPro scantools do not allow ecu programming, you would probably need to look at something like http://www.modacar.com/products/Ford/Mustang/MODAECT for ecu programming..
Yes you can use out scantools withany ELM327 compatible software, the CD comes with a number of the free ones out there...
Main features of our scantools are price, ability to monitor a bigger chunk of CAN transactions without running into buffer full messages, an upgrade path when new protocols appear
Paul
www.obdpros.com
Old 01-23-2008, 03:18 PM   #6
My Photos: (0)
so what exactly is the full functionality of this
if its just to pull info then what can it pull that isn't already on the dash?
anything more helpful?
i do like knowing what can go on under the hood but i would like to be able to unlock the full potential of some of my bolt on mods too
Old 01-23-2008, 04:03 PM   #7
My Photos: (0)
yeah i think this one
M2-ATX 160W Intelligent DC-DC PSU
and this one
OPUS 120 watt DC-DC power Supply DCX3.120
like i said i'm not sure so feel free to correct me and let me know which one is better!
Old 01-23-2008, 04:06 PM   #8
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
Thats a power supply, not an OBDII reader.....
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 01-23-2008, 04:07 PM   #9
My Photos: (0)
hahaha i just posted that in the wrong forum
haha ignore it
Sponsored Links
vB code is On
Trackbacks are Off
HELP! My ECU is dead and I can't find a replacement! wizardPC Off Topic 3 08-11-2007 02:22 PM
Remapping ECU DonFilipo Engine Management, OBD-II, Engine Diagnostics, etc. 1 11-13-2006 02:48 AM
ECU Remapping agrawal_nipun Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-06-2006 07:58 PM
Help me on Sagem SL 96 ECU pashe007 Engine Management, OBD-II, Engine Diagnostics, etc. 0 02-26-2005 05:55 AM
ECU to Car PC problem. cas850 Engine Management, OBD-II, Engine Diagnostics, etc. 4 12-23-2004 01:15 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
