The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 02-16-2008, 10:20 PM   #1
Deric's Avatar
Vehicle: 2006 Ford Mustang Coupe
My Photos: (0)
Bluetooth OBDII adapter - anyone tried it?
Has anyone used the following adapter?
http://store.mo-co-so.com/bluetooth-...face-p-31.html
I'm thinking about getting it but would be afraid I would hit the device with my leg since my car is a standard. Other than that it looks pretty cool.
Deric is offline   Reply With Quote
Sponsored Links
Old 02-19-2008, 07:22 PM   #2
krnpimpsta's CarPC Specs
krnpimpsta's Avatar
Vehicle: 2008 Ford Mustang GT
My Photos: (0)
Hey Deric, good to see you here.
The OBD-ii port actually slides right out (just push it away from you, towards the engine) - and then you can point it in any direction. I had to slide mine out because the thick cable of the SCT Xcal2 was always dangling into my knee.
You could probably slide yours out, attach the device, and then velcro or cable tie it to something under the dash.
2008 Mustang GT CarPC
krnpimpsta is offline   Reply With Quote
Old 02-21-2008, 03:01 AM   #3
My Photos: (1)
Let me know what you find out about this device because I put the same post up a few days ago asking if anyone had used it yet.
Dougw133 is offline   Reply With Quote
Old 02-21-2008, 09:15 PM   #4
dnr250's CarPC Specs
Vehicle: 01 Ford F250 SD Diesel
My Photos: (0)
OBDII Port
Instead of moving the connector, try the following: http://www.obd2cables.com/products/ for a right angle extension. I thought about moving mine, but didn't want to risk pulling out one of the pins.
DNR
dnr250 is offline   Reply With Quote
Old 02-24-2008, 04:49 PM   #5
loginfailed's CarPC Specs
loginfailed's Avatar
Vehicle: 2002 Honda Accord EX-L V6 Sedan
My Photos: (0)
Regarding the cables being in the way, what I did was get one of these:
http://www.obd2cables.com/products/p...products_id=89
and I hard wired it into the wires coming up to my factory OBD2 plug. now I have 2 plugs, one for the dealer to use and one hidden behind the dash that my elmscan is hooked to.
or if you arent good at soldering you could get a splitter like this:
http://www.obd2cables.com/products/p...products_id=85
loginfailed is offline   Reply With Quote
Old 03-14-2008, 01:46 PM   #6
My Photos: (0)
I have the exact same one from a supplier here in UK (cost me £65). The bluetooth signal only seems to be able to be picked up for a distance of about ten feet-ish unless I got a low powered one but picks up fine in the car and on my pc if I have the bluetooth dongle I bought for my pc by the window it picks up fine in the house (mind you I have thick stone walls and its been raining all day, only got it this morning so maybe that affects the indoors reception).
It comes with Vital Engineerings software which is pretty good and once connected polls quickly.
I bought it for my in car pc I am building as I didn`t fancy lots of wires and I think one of the discs it came with even has software on it for mobile phones to access it as well (when I find my memory card adapter and can copy files to my phone again I will check it as that would be neat!).
The OBD Diag software linked to somewhere else on this forum didn`t work with it for some reason, which annoyed me as those dials and things look nice but the included software works great.
I don`t regret buying it, put it that way, and it`s a neat gadget - no wires and I can use it with my home pc, carputer (which is sitting upstairs in testing mode for a while) or mobile phone.
Dave
mentalmummy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Willit work with Parrot bluetooth adapter? carputerwiz StreetDeck Bluetooth 19 03-03-2008 08:19 AM
bluetooth dongle problem toofresh Wireless Communications 3 01-02-2008 10:43 AM
Right Angle VGA Adapter Display Adapter 15 pin Spike General Hardware Discussion 5 07-27-2005 01:33 PM
CSR Bluetooth Adapter needs repluging after start RoyN Wireless Communications 5 11-24-2004 09:54 AM
slim slot dvd rom with wrong adapter, questions mattress General Hardware Discussion 3 10-24-2004 08:51 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
