The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-01-2008, 03:21 PM   #1
Nad
My Photos: (0)
Begineer Advice required:Cars Diagnosis
Hi,
I have a routine workshop where I fix cars using the standard way of opening the hood and start looking around to diagnos the engine or brakes...etc.
I want to start using softwares to do this job for new cars .
As I dont know what is required to buy , I need some advice on what to buy ( softwares, HW ...etc) .
thank you
Nad is offline   Reply With Quote
Sponsored Links
Old 04-02-2008, 08:58 AM   #2
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
thread moved to OBD-II forum.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 04-17-2008, 03:34 AM   #3
My Photos: (0)
If you really plan on doing this for a living, the OTC genisys with the o-scope & 5 gas modules are nice. It's a little pricey, around $8-10k. http://www.autoenginuity.com/ has a nice pc based scanner. But the data provided by even the best scanner in the world is not accurate if the wiring going between the sensors and the control module is at fault. An oscilloscope and a proper wiring diagram are just as important, if not more. Vacuum & fuel pressure gauges are also usefull for diagnosing drivability problems as well.
Diag is also about interpreting the data. ECT readings of -40 degrees indicate an open in the circuit. It could be the sensor, or it could be the wiring. It could even be that the sensor is unplugged. O2 sensor codes could mean a sensor fault, but more likely it is an indication of a misfire - fuel or ignition related.
dieselray is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Small Car, budget complete setup advice Scouse Monkey Car Audio 16 07-18-2007 08:10 AM
Looking for advice regarding touchscreen VGA DanBourque LCD/Display 8 07-08-2007 01:01 AM
Advice on Carputer Setup toyotaman Newbie 9 05-30-2006 06:35 AM
lilliput buttons advice Moneyfink Fabrication 1 03-07-2005 07:51 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
