For Carsoft 6.5
Install drivers for usb-serial adapter cable.In Device Manager set COM port for this adapter to COM1 -you can choose also COM2,COM3 or COM4 ,but Carsoft software installs default to COM 1. If you have installed Carsoft already,make sure the port in Seetings is the same with the one you have choosen for you adapter cable.
It should work this way.
