The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-07-2008, 06:58 AM   #1
Vehicle: 2003/BMW/320D Sport
My Photos: (0)
Implications of having a OBD attached 24/7
What are the Implications of having a OBD attached 24/7 to my car pc?
Or does it not matter?
What if the car is running but the PC is off?
Can any damage occur?
Sorry if this is a noob question
easy is offline   Reply With Quote
Sponsored Links
Old 04-07-2008, 11:06 AM   #2
My Photos: (0)
I do that all the time, most of the interfaces use very little power so leaving your interface connected will most likely use less power than needed to keep you clock/radio etc powered in standby.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 04-17-2008, 03:05 AM   #3
My Photos: (0)
If the car is running with the scanner turned off, it's safe. Some OBD-I scanners require an additional hook up to battery power, OBD-II scanners draw their power from the OBD-II connector. The diagnostic link connector only has power to it with the key in the run or start position. If your OBD-I scanner is connected to a hot at all times circuit (not switched power) there may be a draw on your battery. Some car cigarette lighters are hot at all times, some are switched.
dieselray is offline   Reply With Quote
Old 04-17-2008, 03:49 AM   #4
My Photos: (0)
I Intend to install one of these and I'm OBD-II
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
Old 04-17-2008, 07:35 AM   #5
Rick99TAWS6's CarPC Specs
Vehicle: 2000 Pontiac TransAm WS7
My Photos: (0)
I dont have the same interface - but I am using HPTuners on my carpc for tuning/guages/diagnostics and have found that if the car sits for about 4 days without starting the HPTuners interface will pull the battery down - course then I plan on getting an Optima someday when the current battery dies. I ended up putting a switch in the OBDII power line on my car just in case it is going to sit for awhile - no problem for me during the warmer months with the car sitting much though
Rick99TAWS6 is offline   Reply With Quote
Old 04-17-2008, 08:32 PM   #6
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
I leave mine plugged up all the time. No Problems.
BTW I have an OBDpros unit.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
OBD II connector on an OBD I car HearseNurse Engine Management, OBD-II, Engine Diagnostics, etc. 3 01-20-2008 11:24 PM
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
OBD or special hardware? Jirka Jirout General Hardware Discussion 2 03-04-2007 05:01 AM
Hardwired OBD scanner and motor vehicle inspections 01black_ac Engine Management, OBD-II, Engine Diagnostics, etc. 4 04-29-2006 11:40 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
