The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-07-2008, 11:33 PM   #1
My Photos: (0)
aftermarket gauges installation
hello, i need help with gauges.
i have a 2003 accord coupe ex v6 auto.
i re-located my cluster with a screen. don't flame. the setup is satisfying for my plan. but now i need the last part which are the car's reading:
engine temp, fuel level, rpm, speedo
can someone give me a crash course on installing the gauges.
i have odb2 usb adapter but wasn't satisfy with the quickness and my car apparently lack fuel level readout.
can i tap into my re-located cluster to get the read out for all the gauges? if so how do i know which wire/pin to tap for which gauge.
or can i tap into the ecu instead? i have a copy of my ecu diagram.
http://www.v6performance.net/forums/...3&postcount=15
doens't say anything about fuel level =\
i dont' really want to run each sensor for each gauge.
does my car already have a sender unit for each gauges?
should i look for electronic or mechanical?
please help this is the last obstacle for my carpc setup.
3square is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
G Series Vans Look here. DASH GAUGES (BACKLIT) ChevyG20SS General Hardware Discussion 3 09-12-2007 02:12 AM
Getting started with aftermarket automotive component design (IP) h3rk General Hardware Discussion 7 03-24-2007 03:24 PM
85 nissan want computer to read gauges Bigrick31 General MP3Car Discussion 7 07-11-2006 03:14 PM
For those of you who have aftermarket gauges.. siueclipse Engine Management, OBD-II, Engine Diagnostics, etc. 2 02-20-2005 11:50 AM
Bose HU and aftermarket amp simultaneously wired vberry Car Audio 1 09-06-2004 12:52 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
