The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-12-2008, 07:54 PM   #1
My Photos: (0)
Question whats a good cable?
i want a cheap obdII cable to connect to my 98 mustang, but cables i've looked at are like 100! that seems a bit pricey. it doesn't need to come with software or anything i just need a cable that will go from the mustang to the serial port and it's gotta work with a program called PCMScan, i already bought that software.
jash7 is offline   Reply With Quote
Sponsored Links
Old 04-13-2008, 03:43 PM   #2
My Photos: (0)
anyone?
Old 04-13-2008, 04:24 PM   #3
bbalazs's CarPC Specs
Vehicle: 2001 Renault LagunaII 2.0 IDE
My Photos: (15)
I think those cables are not containing only plastic and wires... are full of electronics, too.
I made my cheap cable from solid U-shaped wire, thickened with soldering metal, put into the appropriate hole trough a paper and fixed with synthetic resin. You can also use a gluegun. This method is faster than going to the shop and purchase one...
For a fixed version I would simply solder the wires under the connector and applying a normal socket on another end...
Alopecia perniciosa
bbalazs is offline   Reply With Quote
Old 04-13-2008, 04:26 PM   #4
My Photos: (15)
OH, I see now, you do not want a cable, but an INTERFACE.
Watch my pictures, the last one shows you a simple K-line-to-RS232.
Alopecia perniciosa
Old 04-13-2008, 04:39 PM   #5
My Photos: (0)
so you know where i can buy a cheap one?
Old 04-13-2008, 05:15 PM   #6
My Photos: (15)
Buuuuuuuuuuy??? Unfortunately, not. I do not give money for a thing like that.
Alopecia perniciosa
Old 04-13-2008, 08:09 PM   #7
My Photos: (0)
so you just made yours? is it compatible with the program i mentioned before? how'd you do it?
Old 04-14-2008, 05:59 AM   #8
My Photos: (15)
Of course. It did take shorter than filling an order form, and waiting, waiting for ever...etc...
I do not know, but I think, it is compatible, as ALL iso-rs232 interface is. It does not anything else, but selecting and level-adjusting the impulses. (e.g. ELM chips are different, they also interpret and translate the messages.)
To design the circuit, printing, photoing, etching the PCB then soldering those components onto. Without design time, it lasted less than half an hour.
The cable I made was discussed earlier. The rs232 serial part was made of an old serial mouse cable and connector.
If it is needed I can send you the .pcb (tango2) file or .eps file.
Alopecia perniciosa
Old 04-14-2008, 08:19 AM   #9
My Photos: (0)
The OP's mustang uses the J1850 PWM protocol for that a simple serial cable will not work. A simple serial cable can be made to work for the ISO protocol found in most EU cars but if you have a vehicle with a non iso protocol you need a protocol converter.
OP check out our interfaces at www.obdpros.com, they also work well with PCMSCAN software.
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 04-14-2008, 08:54 PM   #10
My Photos: (0)
thats what i need, but 84.00 just seems too pricey for something like that.
Sponsored Links
Old 04-15-2008, 02:11 AM   #11
My Photos: (15)
Then you can build an ELM327-based circuit. That is able to communicate with your car by that pwm protocol.
The datasheet and exact descripitoin is on the net.
Alopecia perniciosa
Old 04-15-2008, 09:32 PM   #12
My Photos: (0)
you have a link?
Old 04-16-2008, 03:55 AM   #13
My Photos: (15)
Google.
"ELM327 datasheet"
Alopecia perniciosa
Sponsored Links
vB code is On
Trackbacks are Off
good solution for a Vag-Com cable virtual dash or app?!?! jjcritch Engine Management, OBD-II, Engine Diagnostics, etc. 1 06-10-2007 04:50 PM
Hardware Review: Custom LVDS LCD Cable by MotorCity Giuliano The Review Palace 3 04-27-2007 08:48 AM
Need help on extending the Lilliput cable nthai LCD/Display 5 04-27-2005 12:59 PM
vga cable for lilliput JaxPt LCD/Display 1 02-24-2005 10:52 PM
Need a 31 pin Hirose cable? pigseye Classified Archive 96 03-06-2004 03:15 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
