The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-18-2008, 08:29 PM   #1
Vehicle: 2008 Mazda 3i Touring
My Photos: (0)
Wiring in OBD II Scantool
Hi. I have a Mazda 3 and the OBD II plug is just to the left of the driver inside a small storage area. I'd like to have a scanner attached, but not jabbing my in the leg while I'm driving. Has anyone tried dismantleing the scantool and wiring it directly to the port cables? Preferably in a way that still leaves the port where it is and usable. Does anyone know of a pinout for the connectors? Thanks for any help.
HisSketchiness is offline   Reply With Quote
Sponsored Links
Old 04-20-2008, 12:27 PM   #2
My Photos: (0)
You should be able to splice and solder on the back side of the odb2 plug. Extend the wires a foot or two.Get some .187" female spade connectors. Line up the pin side of the scantool to the odb2 plug. Use the female spade and and crimp them on to the extended wires. Plug in the corresponding wires of the odb2 plug to the pins of the scan tool. Then just zip tie the scan tool module some where secure under the dash. That way you don't have anything sitckin out of the front of the odb port and the dealership/mechanic still can use their tools without problems.
dopey273 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
OBD II and Citroen Xsara ThePohorc Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-02-2008 08:41 AM
OBD II connector on an OBD I car HearseNurse Engine Management, OBD-II, Engine Diagnostics, etc. 3 01-20-2008 11:24 PM
My troubles with the intel/i810 drivers in xorg are fixed. tdb30_ Linux 0 11-03-2007 03:33 PM
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
does this connector means i have obd II ? (Buick 95') tomer Engine Management, OBD-II, Engine Diagnostics, etc. 8 09-03-2007 07:03 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
