The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-26-2008, 12:30 AM   #1
lostreception's CarPC Specs
lostreception's Avatar
Vehicle: Chevy Van G20 and '06 Scion Xb
My Photos: (1)
Do any of the OBDII readers read the OBD subcodes
I had my CEL light come on so i took it to the dealer it was a bad 02 sensor comming up after running it on thier computer at the dealer they pulled 3 other codes that seemed to be from a subsystem , my guess is toyota/scion specific but are there readers on the market that can read these codes too or do only the ripoff artists at the dealers have access to these codes :-/
it was legit as far as the new codes i saw the printout of the diagnostics i just want to get a scantool capable of the most if i can
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Sponsored Links
Old 05-10-2008, 01:51 PM   #2
My Photos: (1)
anyone have a device that does this or an idea?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 05-10-2008, 08:10 PM   #3
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
That's weird. Not sure of what you mean by "sub codes". The way I see it: Our generic readers will read all OBD related codes and additionally "manufacturer specific" codes.
Most "P0xxx" codes are OBDII generic, and our scan tools will read and show what they mean, for example: P0171 Fuel Mixture Lean.
However, our scan tools will also read "P1xxx" (note the "1"), but our scan tool will not explain what they mean, or will state "manufacturer specific code".
Regardless, "our" scan tools should read ALL codes in a PCM (ECU).
I know Toyota's...there is no such thing as a "sub system". Why your scan would not read the other codes...don't know.
What codes are (where) they?
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 05-10-2008, 08:35 PM   #4
muldrick's Avatar
My Photos: (2)
I just realized. You (they) might be talking about "trip failures".
In most cases a code requires 2 trip failures to set.
In your case it is possible the additional codes where trip failures which means they had one trip failure (each) and had not yet "matured", or had not yet ran through 2 failed trips...which sets the "hard" code.
No, most scanners (except dealers' or an expensive SnapOn scan tool) will not read trip failures.
Old 05-11-2008, 01:39 PM   #5
My Photos: (1)
yes i believe that was is then it said something about a shorted sensor
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Sponsored Links
vB code is On
Trackbacks are Off
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
OBDII Signal Splitter (for Infiniti G35) Caelric Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-14-2007 08:32 PM
OBDII read and programming ECU johnwrx Engine Management, OBD-II, Engine Diagnostics, etc. 1 11-11-2005 09:48 PM
Read OBDII Source Code? Zharvek Engine Management, OBD-II, Engine Diagnostics, etc. 6 05-19-2005 07:31 PM
Where to hook up to read OBD? Ritalin Kid General Hardware Discussion 6 08-17-2002 09:12 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
