The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Thread Tools Display Modes
Old 04-29-2008, 07:48 AM   #1
My Photos: (0)
cant locate OBD
Hi All
Please forgive this complete noob for silly question!
I am based in a India and own a Honda Accord 94 Model CB4 (Japanse made, auto transmission, 4 door, Sedan class) and recently got it screwed by a local Mechanic. The tuning of Auto Transmission has gone crazy and the RPM meter freaks. I referred to a more trained mechanic who said the OBD has to be done for tuning it back.
Now the problem is he has tried all spots but cant locate the OBD connector. I read over net that its behind Coin/Ash Tray but the mechanic dint find there as well. I am attaching 2 pictures of DashBoard... if anybody could please hep locating OBD connector I would be very grateful.
Ankit
ankitudaipur is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 07:28 AM   #2
My Photos: (0)
This database should help you out:
http://obdclearinghouse.com/oemdb/
Big_Mike is offline   Reply With Quote
Old 05-06-2008, 10:09 AM   #3
My Photos: (0)
I use http://www.fixexpert.com/wiki/OBD-2+Location to fix any OBD2 port.
94, seem pre-odb2, but from the site, I see it should be Closed: In front of the shifter, behind the ash try.
Mecanixxx is offline   Reply With Quote
Old 05-08-2008, 03:23 AM   #4
My Photos: (0)
Thanks Guys, mine is a RHD and I found DLC on passenger side below Dash. I thought DLC and OBD are 2 different thinks but it seems the only option I have is DLC. However I was not able to find the connector in scanner machine to connect to that 2 Pin DLC. So finally had to use a jumper on DLC and go for a self diagnostic.
Any hep about convertor for 2 pin to 3 pin for DLC?
Sponsored Links
vB code is On
Trackbacks are Off
OBD II connector on an OBD I car HearseNurse Engine Management, OBD-II, Engine Diagnostics, etc. 3 01-20-2008 11:24 PM
OBD or special hardware? Jirka Jirout General Hardware Discussion 2 03-04-2007 05:01 AM
OBD 1 Diagnostics software? MaleBuffy Engine Management, OBD-II, Engine Diagnostics, etc. 3 06-13-2005 07:05 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
