Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 05-11-2008, 03:40 PM   #1
greatwhite's Avatar
elm 327 won't talk to PCM..........or maybe it's the other way around.......
I picked up an elm 327 based reader last year and just got around to trying it today. It's usb and uses the ftdi chip (I had it open already). The PIC is a PIC18 as you would expect. It only has one LED and that flashes as you plug it in and then goes blank.
I'm using Proscan 5.1.
I can communicate with the elm as the log shows the proggy sending out the commands and getting the appropriate responses (ie elm 327 v1.2, etc) right up to the point where it transmits 01 01 and then there's no repsonse from (apparently) the vehicle obdII.
The car is a chrysler 2004 300M, and it uses VPW SAE J 1850.
Anyone have any ideas how to get the vehicle and elm to "talk nice"?
Any settings I could be missing?
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-12-2008, 09:33 AM   #2
Based on the description looks like it is not an obdpro but anyways...
Try connecting via hyperterminal and then type in 0100 that should show what pid's are supported maybe 0101 is not a supported pid.
Paul
michbound is offline   Reply With Quote
Drivers ELM 327 USB Dj-[NRG] Engine Management, OBD-II, Engine Diagnostics, etc. 9 10-11-2008 04:02 PM
Bought a ELM 327 and it doesnt work!!! HiJackZX1 Engine Management, OBD-II, Engine Diagnostics, etc. 64 08-09-2008 10:10 PM
obd2 elm 327 interface? mrcgibb StreetDeck 0 04-22-2008 05:12 PM
Elm 327 emulator StefanVikman Engine Management, OBD-II, Engine Diagnostics, etc. 8 03-25-2008 11:21 AM
ELM 323 or 327? Hoohar Engine Management, OBD-II, Engine Diagnostics, etc. 5 01-24-2007 02:19 PM
