Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-29-2008, 08:51 PM   #1
Palmer Performance Dash Command using my Bluetooth ELM
I am currently running Centrafuse, and there are a few gauge options, but none compare to Palmer Performance Dash Command.
In just a few days I was able to put together a Mazda RX-8 skin, with very little experience with this type of thing. I finally have a real speedometer =) along with a much more useful selection of gauges.
I would highly recommend this program to utilize your ELM device.
I still need to find a way to incorporate this program into Centrafuse, so if anyone has any ideas let me know!
flyboyindy is offline   Reply With Quote
Old 06-30-2008, 04:33 AM   #2
What kind of refresh rate on the data are you seeing? Is it using proprietary codes, or are you still stuck at 12 sensor refreshes per second? (around 2 per second total with that many gauges).
I wanted to try out their program, but it dosent let you connect to your car on the trial version, kinda turned me off to them unfortunatly.
malcom2073 is offline   Reply With Quote
Old 06-30-2008, 07:21 AM   #3
Well for $25 bucks I was willing to give it a try... I dont know what the refresh rates are, I know that the ODBII plug in in Centrafuse sucked, so I went to this instead. Just seems a bit smoother and im really going for more of the "cool factor" on this than anything else.
Old 06-30-2008, 11:57 AM   #4
PPE
PPE's Avatar
Cool looking dashboard!
BTW - we just released a new software version that now allows you to connect to the vehicle and monitor Engine RPM without a license key - it's a free download.
PCMSCAN - Check it out at: http://www.palmerperformance.com
PPE is offline   Reply With Quote
Old 09-12-2008, 12:28 AM   #5
hey would you mind uploading the .dxl for this dash?
ssadiq is offline   Reply With Quote
Stream Bluetooth music from CarPuter to In Dash Reciever? dbacs Bluetooth Hardware 4 05-23-2008 09:58 AM
BlueTooth PC adapter to Dash unit w/bluetooth? dbacs General Hardware Discussion 0 05-22-2008 11:15 PM
NEED RECOMMENDATION: In Dash Double Din GPS with CDMA Bluetooth RabbiDan Newbie 1 10-19-2007 12:24 AM
Bluetooth Dongle Not Working correctly KingsDude Wireless Communications 6 05-17-2007 01:30 PM
