Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-16-2008, 02:56 PM   #1
Can you guys please help me??? OBD Renault Clio help needed!
Hello all,
Right, I have spent the last two days trying to find out what type of OBD my 1999 Renault clio 8v spi uses. It is a UK car. It has a 16 pin connection under the ashtray. It has connectors in pins 1,2,10,12,13,16.
I really do not have a clue.
Thanks for reading,
Ben
madtoonbull is offline   Reply With Quote
Old 08-04-2008, 05:57 PM   #2
Not EOBD, almost for sure. EOBD not required for Europe cars...
Quote: Originally Posted by madtoonbull View Post
Hello all,
Thanks for reading,
Ben
until 2001.
Do not know what preceeded EOBD2 in Europe/UK. Here in USA it was OBD1.
Sincerely,
MarcW.
marcw is offline   Reply With Quote
Old 10-05-2008, 08:07 AM   #3
hi have you managed to find out what obd port is on the clio and what protocol it uses?
malawigold is offline   Reply With Quote
Old 10-05-2008, 02:24 PM   #4
The pins listed do not map to those used by OBD II...
so hard telling what the protocol is. Can't access my company's internal web site where a list of European vehicles that were tested are listed so can't look to see if a '99 Clio on it. Since OBD II not required until after IIRC 2001 (for gas, and even later for diesel) vehicles in Europe and I was only interested in testing/verifying OBD/EOBD II compatibility might not have probably didn't even bother testing any '99 Clio unless a contact in Europe had one handy as a personal vehicle. Most cars tested were newer models at dealerships or vehicles were rented or had access to at companies and their fleets of vehicles.
Short answer is I did not find out what protocol is used by '99 Clio.
Sorry.
Sincerely,
MarcW.
OBD or special hardware? Jirka Jirout General Hardware Discussion 2 03-04-2007 05:01 AM
50 things about guys that girls DON'T know...but will now!!! Rafster Off Topic 28 08-22-2006 09:33 AM
OBD II Help Needed LM3 Engine Management, OBD-II, Engine Diagnostics, etc. 4 08-07-2006 02:14 AM
smart guys needed: why is there a voltage drop in this situation? Bobby Digital Power Supplies 6 06-03-2004 06:11 PM
