Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 07-25-2008, 06:13 PM   #1
OBDII vehicle speed acquisition
I am working on a small project that doesn't seem to be so simple anymore.
I have a data acquisition (USB-1408FS) unit hooked up to a laptop.
I would like to record vehicle speed from the OBDII port, and input it into the data acq.
The vehicle is a 2005 Ford truck.
What is the most efficient way of doing this? There has to be a way, but I can not seem to find a simple way.
Thanks in advance for your reply.
Steve
S_Steve is offline   Reply With Quote
Old 07-25-2008, 06:50 PM   #2
Confusion Master
Enforcer's Avatar
Depends on what you are connecting to the OBDII with
here is a VB6 class for the ELM
http://www.mp3car.com/vbulletin/engi...vb6-class.html
Enforcer is online now   Reply With Quote
Old 07-25-2008, 06:52 PM   #3
Not entirely sure what you mean by "inputting it into the data acq", but your best bet for reading speed would be to buy an OBD2 tool, such as those sold by http://www.obdpros.com/(This is an ELM unit, which is compatable with all programs supporting the ELM327 and most programs supporting the ELM323) , and connecting via serial (or via a program), and as you can see from http://en.wikipedia.org/wiki/OBD-II_PIDs that list, 010D is the command to send to retrieve vehicle speed.
malcom2073 is offline   Reply With Quote
Old 07-28-2008, 01:06 PM   #4
I have an existing data acq unit that I am trying to feed vehicle speed into. The data acq measures a voltage, that is it. I could use one of the many existing components and input vehicle speed into the laptop, however I was initially trying to input the information into the data acq module I already have, even if it would be slightly more work.
Basicly here is my ideal setup even though it is not efficient.
OBDII port > Cable > Module that sends command to OBDII and recieves speed data, then outputs the data as a voltage > Cable > Data Acq > Cable > Laptop running software I already have.
I don't know if this can be done easily or not.
Thanks,
Steve
Dashcam video with GPS speed imprint - court date soon... erkme73 GPS 122 07-31-2008 11:45 AM
Software that write GPS speed to TXT file? der_mof GPS 1 06-22-2007 12:44 PM
New Centrafuse Update, manual install with Debug OBDII version for testing veetid Centrafuse 22 04-15-2007 09:38 PM
Feature request: speed camera notifications based on current speed surfatwork Map Monkey 2 08-31-2005 06:01 PM
PC / Vehicle interface bluelip General Hardware Discussion 7 07-15-2005 01:24 PM
