Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 09-30-2008, 01:00 PM   #1
Titang9 is an unknown quantity at this point
Which is the best scan tool for Infiniti G35?
I’m looking for the best (at a reasonable price) scan tool, or something laptop friendly, to detect parameters or codes (OBDII).
I’m better inclined to the laptop use.... like AUTO TAP!
Any suggestions?
Titang9 is offline   Reply With Quote
Old 09-30-2008, 03:54 PM   #2
VENDOR - OBDPros
michbound is on a distinguished road
I guess it depends on what you want to do if you just want the basic OBD II parameters than the OBDPro will do the job, plus now it offers free upgrades over the web via remote reflash.
If you want to read enhanced Nissan specific parameters yes something like AutoTap would be required
Paul
michbound is offline   Reply With Quote
Old 09-30-2008, 04:47 PM   #3
Thx for your reply Michbound!
I’ve been hearing about Auto-Tap; I just want to know, basically, the difference between the OBDpro and Auto Tap!
Can Auto Tap read more sensors? …..!!! Is it worth the extra cost?
By the way, I own a Mustang GT 1997, Acura RL 1999 and the G35 2003…strange combination, I know!!!!! All OBDII systems.
Robert
Old 09-30-2008, 06:29 PM   #4
VENDOR - OBDPros
Robert
Hi Robert,
No the Autotap cannot read extra sensors for the Acura or the G35, for the Mustang they do have an add on software that will read certain additional parameters.
Also on a 97 GT not sure how many of the additional parameters would be support.
For the basic sensors
A/C System Refrigerant Monitoring Status
Auxiliary Input Status
Catalyst Monitoring Status
Comprehensive Component Monitoring Status
ECT
EGR System Monitoring Status
Engine Load
Engine Load
Engine Speed
EVAP Vent Solenoid Command
Evaporative System Monitoring Status
Fuel Pressure
Fuel System Monitoring Status
Fuel System Status Bank 1
Heated Catalyst Monitoring Status
IAT
Ignition Timing
LTFT B1
LTFT B2
MAF
MAP
Misfire Monitoring Status
O2 Sensor - B1S1
O2 Sensor - B1S1 (mV)
O2 Sensor - B1S2
O2 Sensor - B1S2 (mV)
O2 Sensor - B1S3
O2 Sensor - B1S4
O2 Sensor - B2S1
O2 Sensor - B2S2
O2 Sensor - B2S3
O2 Sensor - B2S4
OBD Requirements
Oxygen Sensor Heater Monitoring Status
Oxygen Sensor Monitoring Status
Secondary Air System Monitoring Status
STFT B1
STFT B2
Throttle Position
Vehicle Speed
The OBDPro will provide way better bang for the buck than the Autotap, but then if you need the additonal parameters for the Mustang and there is a long list here http://www.autotap.com/enhanced_parameters_ford.asp
Then you will need to get the autotap or purchase the add on module from PCMScan that will allow the OBDPro to read the additional Ford parameters.
One additional thing... with the OBDPro you can use software from a wide variety of developers such as the OBD2007, OBDDiag, PCMSCan, Dashcommand, Scanmaster etc whereas with the Autotap you are locked into their own version of the software this might be an additional factor in your evaluation
Paul
Paul
Scan Tool says not connected but it is beetlebailey Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-09-2008 01:55 PM
I'm a nubie looking for a scan tool or program raceear Engine Management, OBD-II, Engine Diagnostics, etc. 3 02-01-2008 12:58 AM
PC based scan tool or handheld edvan22 Engine Management, OBD-II, Engine Diagnostics, etc. 10 08-08-2007 02:40 PM
Scan Tool for Air Bag Light Jamen Engine Management, OBD-II, Engine Diagnostics, etc. 10 10-31-2006 12:44 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
