Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 01-27-2009, 02:11 PM   #16
drewbp is an unknown quantity at this point
I have an obdpros connector and have never been able to get it to connect to this program. I use dashcommand which sometimes takes 2 tries to connect, the first I guess does a reset, and then times out before reconnecting but always connects by the second try.
I also use the obdpros scantool, and have only been able to get it to connect when I physically disconnect the usb connection. If I use dashcommand at all, I cannot get it to reconnect.
However, I have never been able to get your program to connect. I will keep trying, but do you have any suggestions, or can I help you in any way to debug.
drewbp is offline   Reply With Quote
Old 01-27-2009, 02:47 PM   #17
VENDOR - OBDPros
michbound is on a distinguished road
I suspect it might be the baud rate setting that the program defaults did you ensure that the speed was set to 9600 on the setup screen?
of course mjo151 might have additional suggestions...
Paul
www.obdpros.com
michbound is offline   Reply With Quote
Old 01-27-2009, 06:59 PM   #18
VENDOR - OCTech
mjo151 is an unknown quantity at this point
As michbound suggested, I would first verify that you are using the correct com port and baud rate. If you have these set correctly, then the following will help me debug exactly what is going on:
1) Try to connect to the device
2) Goto the Device Traffic tab on the Diag page
3) Send me a screen shot of the output (sorry the save button apparently doesn't work correctly)
Please note that you'll need the second install that I posted in order to get debug output on the Diag page.
mjo151 is offline   Reply With Quote
Old 01-29-2009, 12:31 AM   #19
Okay Got it to connect
Okay so I set the program to 9600 and it connected. My question is then why the other speed settings. My OBDPro connector is set at 38400, so how can I get it to connect at the faster speeds.
Also, the overall MPG seems to be accurate, but the instantaneous seems very eratic, sometimes going up over 50MPG. It starts at 19 or 20 MPG and then slowly climbs to up and over 50MPG.
Old 01-29-2009, 09:59 AM   #20
VENDOR - OBDPros
Yeah instantaneos would jump around and be pretty high for short durations...
Old 01-29-2009, 08:17 PM   #21
VENDOR - OCTech
If you got it to connect at 9600 baud then your OBD device must be set to communicate at 9600 baud. The data sheet should tell you how to set it to higher baud rates, then you'll have to select that baud rate in my software.
The instantaneous MPG is just that...MPG at that instant. If you are moving pretty fast then take your foot off the accelerator the value should spike fairly large because you are using very little fuel to go a given distance. It does get averaged by an FIR (moving average) filter, but expect that number to fluctuate. The total and trip MPG should find a steady state value the more you use the software.
Old 01-29-2009, 10:35 PM   #22
VENDOR - OCTech
I received the ElmScan 5 today and was able to do some debugging this evening to get it to work. I rewrote part of the communication interface to the device so hopefully this will be more reliable. The new setup that I'm posting works with the Elmscan 5 right out of the box...I did not change any settings on the scantool itself.
Remember to set the right com port and baud rate before trying to connect. Enjoy!
Old 01-29-2009, 11:03 PM   #23
Uraijit's Avatar
Uraijit is infamous around these parts
Quote: Originally Posted by drewbp View Post
Have you embedded this into Ride Runner yet. If so I would love to know your window name for the embed.
Thanks.
Edit: Figured it Out.
Why don't people ever share the answer after they find it?
Greedy
-Adj.
Anybody who makes significantly more money than you do.
The Hoe-Puter Worklog
Progress (Phase one):
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Uraijit is offline   Reply With Quote
Old 01-29-2009, 11:12 PM   #24
VENDOR - OCTech
Window name is "OBD2 Monitor". I've been using opening it using the LAUNCH function.
Old 02-02-2009, 12:21 PM   #25
VENDOR - OCTech
Anyone have a chance to try the new setup that I posted? Any feedback would be helpful and appreciated.
Old 02-02-2009, 01:15 PM   #26
pcpete's Avatar
pcpete is on a distinguished road
I'll be giving a try later today....
pcpete is offline   Reply With Quote
Old 02-02-2009, 05:32 PM   #27
pcpete's Avatar
just did a quick test..good job man, she's working now!
i'll see if i can post a youtube of her in action later...
Old 02-02-2009, 11:27 PM   #28
Here is the full line for the embedding of the program:
"MyApp72","Load;OBD2Monitor.skin;OBD2Monitor;C:\Pr ogram Files\OBD2 Monitor\OBD2Monitor.exe;OBD2 Monitor"
Old 02-06-2009, 05:09 PM   #29
nav888 is an unknown quantity at this point
Smile
Works like a charm! Lookng forward to see your metric option in action!
nav888 is offline   Reply With Quote
Old 02-09-2009, 03:29 PM   #30
Laminar's Avatar
Laminar is an unknown quantity at this point
How are you calculating instantaneous mpg?
1999 SVT Contour
3.0
Laminar is offline   Reply With Quote
Cellphone software for Bluetooth OBD2 mrlate Engine Management, OBD-II, Engine Diagnostics, etc. 0 04-02-2007 09:13 AM
OBD Free software Lowtechguy Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-14-2007 05:39 AM
Free USA GPS software? Blue6Studios Software & Software Development 12 02-27-2006 05:05 AM
New software just like Front Row, but free skizot MacCar 2 01-11-2006 09:48 PM
FYI: Awesome FREE forum software...... mp3pc Off Topic 1 06-13-2001 09:40 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
