Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 02-27-2009, 08:56 PM   #61
VENDOR - OCTech
mjo151 is an unknown quantity at this point
Quote: Originally Posted by rp_guy View Post
i tried it on my dad's oldsmobile intrigue and my acura cl. both worked fine, but when i tried the app on my gf's chevrolet optra (suzuki forenza clone), the app couldn't read any sensors or DTC info. i actually have another program on my s60 phone, and it was able to read what it could (water temp, engine speed, etc). i will get the output log tomorrow.. but any idea why this is?
Not entirely sure. Do you know what OBD2 protocol the car uses? (e.g. CAN, PWM, etc.).
mjo151 is offline   Reply With Quote
Old 02-28-2009, 03:26 PM   #62
pauleley is an unknown quantity at this point
Will this OBD2 OBD-II AUTO SCAN Tool work with you software. I have a Fiat Scudo (Work's) Van im trying to setup a CarPC in.
http://cgi.ebay.com/ebaymotors/_Auto...ayphotohosting
pauleley is offline   Reply With Quote
Old 03-01-2009, 06:29 PM   #63
Blankstar85 is an unknown quantity at this point
Exactly what i was looking for mjo151 you have a pm
Blankstar85 is offline   Reply With Quote
Old 03-01-2009, 07:44 PM   #64
VENDOR - OCTech
This looks like one of the cheaper scantools so hard to say for sure it if would work. Based on the compatible software listed I would expect it to work with my software but I can't say for sure.
Old 03-08-2009, 12:19 AM   #65
Couldn't get it to connect, Ill have to try a higher Com number. I have Vag-com. With my cable hooked up I was able to connect / read on com1, Any way to be able to select this com with your program?
Old 03-08-2009, 11:12 AM   #66
VENDOR - OCTech
You should be able to select any com port that is available on your computer. The software determines what ports are available when it starts. You can set the com port and baud rate on the setup page. If you think you have both of those set correctly and it still doesn't connect, then send me the output on the Diag->Device Traffic page when you try to connect.
Old 03-09-2009, 03:02 PM   #67
kd5feb is an unknown quantity at this point
I have been using this software for about a week now with an ELM327 (clone I believe, considering the price I paid.) and it connects up just fine @ 9600 and polls and works pretty nice. The only thing I have noticed that is a pain is when my car PC goes into hybernation after I turn off the ignition, all of the polling times for the indovodual PIDs will go back to 0 when I start it back up. This does not happen when I exit the software before killing the ignition and the PC hybernates, only if the software is running when it hybernates. When the PC comes back on, the software reconnects but all of the PID polling times are @ 0 and I have to manually reset them to whatever period. It would be nice if a check box or some option could be incorporated into the software that would make the polling periods sticky, regardless how the software quits and restarts. Also, more graphics on the O2 sensors and intake manafold and fuel trim data would be nice. I am not a coder so I do not know how hard this would be.
jkt
kd5feb is offline   Reply With Quote
Old 03-09-2009, 10:22 PM   #68
VENDOR - OCTech
jkt
Thanks for the feedback. A few others have mentioned the inconvenience of having the PIDs reset so I'm working on a solution for that. It also may be possible to automatically disconnect/reconnect when hibernating so that may be another solution.
Old 03-10-2009, 09:22 AM   #69
Another thing I would like to see that I think would help is when during night dosplay mode, the graduations of the guages and the numbers be a lighter color. The dark color against the dark background currently make them a bit hard to read quickly. IMHO
jkt
Old 03-10-2009, 06:48 PM   #70
Alright So issues lol, Vag-com never has a problem connecting. It is definately Com 3 that Vag is connecting through. I have tried Com 3 with your program and always get a connection time out. I am using an OBDII Serial USB cable. http://cgi.ebay.com/ebaymotors/USB-V...spagenameZWDVW
Any help be appreciated Thanks!!
Old 03-10-2009, 08:21 PM   #71
VENDOR - ScanTool
Vitaliy is on a distinguished road
Blankstar,
AFAIK this software will only work with ELM327-based interfaces, or interfaces that emulate the ELM327 command set.
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $79.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 03-10-2009, 08:41 PM   #72
VENDOR - OCTech
Quote: Originally Posted by Vitaliy View Post
Blankstar,
Vitaliy
Sorry Blankstar, I didn't realize the scantool wasn't ELM327 compliant, which the software is only compatible with.
Old 03-10-2009, 10:19 PM   #73
No prob thanks!!!
Old 03-11-2009, 12:04 PM   #74
smblt is an unknown quantity at this point
Do you have a link to download this somewhere? I scanned the messages and don't see one. Thanks.
smblt is offline   Reply With Quote
Old 03-11-2009, 05:59 PM   #75
jeelo is an unknown quantity at this point
i was looking for the download link as well
jeelo is offline   Reply With Quote
Cellphone software for Bluetooth OBD2 mrlate Engine Management, OBD-II, Engine Diagnostics, etc. 0 04-02-2007 09:13 AM
OBD Free software Lowtechguy Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-14-2007 05:39 AM
Free USA GPS software? Blue6Studios Software & Software Development 12 02-27-2006 05:05 AM
New software just like Front Row, but free skizot MacCar 2 01-11-2006 09:48 PM
FYI: Awesome FREE forum software...... mp3pc Off Topic 1 06-13-2001 09:40 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
