Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 01-22-2009, 08:52 PM   #1
VENDOR - OCTech
mjo151 is an unknown quantity at this point
Free OBD2 Software anyone? (No Longer Free)
About six months ago I bought an OBD2 scanner from OBDPro's. I looked at some of the free (and paid) software out there but never found anything that I really cared for, so I decided to write my own. I've been developing, testing, using off and on for a couple of months now and am pretty satisfied with it.
Here are some features:
- MPG calculation including total MPG, instant MPG, and three trip meters (requires mass air flow sensor)
- Fuel usage estimation (total and instantaneous)
- Distance traveled estimation
- Load calculation
- Coolant temp calculation
- Logging of speeds and fuel usage
- Reading and clearing trouble codes (displays code + description)
- Monitoring of all supported PIDs
- PID monitoring priority (e.g. Update speed every cycle, engine coolant temp every 20 cycles)
I am interfacing to the car with an OBDPro usb scantool (www.obdpros.com). I have a Pontiac grand am and have only been able to test on this so I don't know how well other protocols will work. If anyone is interested then PM me and I can send (or post) an install.
Attached are some pics.
mjo151 is offline   Reply With Quote
Old 01-22-2009, 10:16 PM   #2
pcpete's Avatar
pcpete is on a distinguished road
Wow, pretty impresive, wouldn't mind trying it with mty elmscan 5 usb, will copy this in PM...
pcpete is offline   Reply With Quote
Old 01-23-2009, 09:11 AM   #3
PCBum's Avatar
PCBum is on a distinguished road
WOW, nice! Post link?
"If at first you don't succeed, keep on suckin' till ya do succeed" (Stooges)
PCBum is offline   Reply With Quote
Old 01-23-2009, 12:06 PM   #4
VENDOR - OCTech
Ok I attached the setup. One thing to note is that this uses the .NET 2.0 framework so you will need to have that installed.
Please let me know if it works/doesn't work, etc. I've been using it for a while and it's been pretty stable, but then again I wrote it so I know how not to break it .
Old 01-23-2009, 12:16 PM   #5
VENDOR - OCTech
By default the software scans a few PIDs (speed, mass air flow rate, load, engine coolant, fuel system status, RPM). To add others, double-click the row in the Supported PIDs tab on the Diag page. You can also change polling priorities on the PID Monitor Setup page by double-clicking the polling rate column for each row.
Old 01-23-2009, 01:24 PM   #6
pcpete's Avatar
Installed it at work to play around with interface and such, looks really pro, from install to use... seems to be touch screen friendly, too.
Will install in carputer later today and post results...
Old 01-23-2009, 07:56 PM   #7
pcpete's Avatar
Ok, tested in car on the way home from work, would not connect, said timeout error on bottom.
It's an Elmscan 5 USB, works fine with scantool and palmer dashcommand software.
Old 01-23-2009, 10:23 PM   #8
VENDOR - OCTech
I don't have an ELMScan 5 to test with, so I tried adding some debug and another command to see what's going on. I'm guessing it's getting hung up trying to issue an identify command to the device. Try this and send me the output of the Device Traffic tab on the Diag page.
Old 01-23-2009, 11:25 PM   #9
pcpete's Avatar
OK, heading out to get some groceries, will give it a shot and let you know...
Old 01-24-2009, 01:42 AM   #10
pcpete's Avatar
Ok, tried it with the update, wanted to take screenshots, but my **** dinovo mini kb doesn't have printscreen button.
The log didn't save anything, but it did show something on the screen.
I was able to capture a video of my desktop, I'll try to upload it on youtube..
Here it is:
http://www.youtube.com/watch?v=wLHqP1c9kXk
Old 01-24-2009, 09:37 AM   #11
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a splendid one to beholdmalcom2073 is a splendid one to beholdmalcom2073 is a splendid one to beholdmalcom2073 is a splendid one to beholdmalcom2073 is a splendid one to beholdmalcom2073 is a splendid one to beholdmalcom2073 is a splendid one to behold
Hey, just a suggestion. If you use portmon: http://technet.microsoft.com/en-us/s.../bb896644.aspx you can see the serial port traffic. Maybe this will give you a clue what the elmscan software is doing that mjo151's software is not.
malcom2073 is offline   Reply With Quote
Old 01-24-2009, 11:04 AM   #12
VENDOR - OCTech
Not sure if I'll time today, but I think Scantool is open source so I'll take a look and see what they're sending to the device on connect. It's possible that what I'm sending is only compatible with the obdpro scantool.
Old 01-25-2009, 02:35 AM   #13
VENDOR - ScanTool
Vitaliy is on a distinguished road
It is indeed open source. ScanTool.net doesn't do anything special. On startup, it resets the chip (ATZ), turns off echo and linefeeds, sets the protocol to automatic, and waits for the ECU to time out. Somewhere in between, it asks for the chip version and manufacturer.
One thing I noticed is that your software did not issue the ATZ command to reset the chip. IMHO, it's a good idea to do that, it gives you reasonable assurance that you are starting with a more or less standard setup.
Best regards,
Vitaliy
— Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is offline   Reply With Quote
Old 01-25-2009, 10:08 PM   #14
drewbp is an unknown quantity at this point
Have you embedded this into Ride Runner yet. If so I would love to know your window name for the embed.
Thanks.
Edit: Figured it Out.
drewbp is offline   Reply With Quote
Old 01-25-2009, 10:38 PM   #15
VENDOR - OCTech
OK so I should be getting an ElmScan 5 to test from the good guys at scantool.net. I'll update when I have something new to try.
Cellphone software for Bluetooth OBD2 mrlate Engine Management, OBD-II, Engine Diagnostics, etc. 0 04-02-2007 09:13 AM
OBD Free software Lowtechguy Engine Management, OBD-II, Engine Diagnostics, etc. 2 03-14-2007 05:39 AM
Free USA GPS software? Blue6Studios Software & Software Development 12 02-27-2006 05:05 AM
New software just like Front Row, but free skizot MacCar 2 01-11-2006 09:48 PM
FYI: Awesome FREE forum software...... mp3pc Off Topic 1 06-13-2001 09:40 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
