Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc.
Old 06-10-2009, 08:34 PM   #16
VENDOR - ScanTool
Vitaliy is on a distinguished road
Quote: Originally Posted by fanl View Post
Updating Solution:
To solve this problem is very simple:
Just issue this comand to ELM327: AT SH 8010F1
SH = Set Header, it will use the proper header for the non OBD KWP2000 of Alfa romeos.
Tested and it is initializing comunication.
Thanks to p2psmurf.
Are you able to get any useful data from the vehicle?
— Did you know that MP3Car sells OBD-2 interfaces? Get your ElmScan 5 Compact for only $59.95!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
Vitaliy is online now   Reply With Quote
Old 06-11-2009, 12:06 AM   #17
fanl is an unknown quantity at this point
I got a string of bytes that were not the tipical awnser like it is suppose to be.
I expected something starting with 41 01.. but i got F7 or 70 as fst byte.. I must try again to get the precise information. As soon I get it tested again I'll post.
fanl is offline   Reply With Quote
Old 06-11-2009, 10:46 AM   #18
VENDOR - ScanTool
My guess is that the first byte was actually 7F (negative response)?
Vitaliy
Old 06-15-2009, 10:53 PM   #19
hello ppl! Follow the communication I had with the car.. help me understanding it.
Code:
ELM327 v1.3a >at sh 8010f1 OK >at tp 5 OK >0001 BUS INIT: OK 7F 00 11 >01 NO DATA >0002 NO DATA >0101 NO DATA >at cp ? >at pc OK >at sp 5 OK >0001 BUS INIT: OK 7F 00 11
Old 06-15-2009, 11:06 PM   #20
another string that "worked"
Code:
>8101 BUS INIT: OK C1 EF 8F
another...
Code:
>1800ff00 58 03 11 72 62 11 73 21 D6 00 A8
Old 10-13-2009, 10:59 PM   #21
Ive had access to Fiat documentation, and something come up to my mind:
TO start a communication 81h must be issued, and the awnser is what is shown in my last post.
Then to startDiagnosticSession 10h must be issued followd by the type of session and the baud rate.
Baudrate?! What's going on here? The baudrate of the K line will be changed or other line must be used in the DiagnosticSession ?
Can anyone help me?
About ebay's ELM327 (szhid seller & others) luichi24h Engine Management, OBD-II, Engine Diagnostics, etc. 69 08-28-2009 04:24 PM
Elm327 v1.3 chip released glm Engine Management, OBD-II, Engine Diagnostics, etc. 10 10-18-2008 06:55 PM
ELM327 ver 1.2a didn't connect Lancer 1999 CK1A nbctcp Engine Management, OBD-II, Engine Diagnostics, etc. 14 09-24-2008 08:21 PM
KWP2000 - and serial communication Mcnovy Engine Management, OBD-II, Engine Diagnostics, etc. 8 08-05-2008 02:41 PM
